mark1122 wrote:
Thats what i did to mine as well. i regret it somewhat. i did it so i could keep the rim centered.
it forced me to use a 170 tire instead of the 180.
I will try going back to the stock hub and fitting a 190 tire next time i nee a new tire. This will force me to run the rim to the right but i'd like to try it anyways. I just love the look of those big ass tires.
Again, nice work ROY.
Thanks Mark.
Its a pain in the ass that centering question, I reckon with this milling I can come very close (in fact straight on) to centering and still use the original tire...BUT, as we know, its hard to do measurement when the parts not fit together properly.
It all will reveal when its machined to fit. :dry:
And as 531blackbanshee says, he is riding with the rear tire a little out of center, and doesnt notice any problems.
Wonder if there are (any?) new bikes with a offset rear?
Leon: It was a great concert.
:woohoo:
Here is the band for those who might be interested:
here is the band for those who are interested
Saxjonz:
Thanks for liking my project.
I am using Gun-Kote, thats oven baked paint that will hold 300 degrees Celsius after its been cured in the oven.
Its curing time after I have sprayed it on its approx 1 hour in the oven with something around 160 degrees Celsius.
Its a very thin paint, and its also dissipate heat, that I think is very interesting.
Its a lot about it the previous pages somewhere.
Here are some from the
Homesite Gun-Kote:
Gun Kote and its uses:
1. Exterior of weapons (including clips) of all types from handguns to G5 and G6 heavy artillery.
2. Engine blocks and heads to dissipate heat.
3. Engine water jackets and water pumps to act as a barrier between dissimilar metals.
4. Protection from corrosion while helping to transfer heat and coolant.
5. Transmission cases and rear end housings to transfer heat out of the housings and when used with Gear Kote and Engine Gard Oil Treatment will result in an average 35% reduction of heat.
6. Radiators, Oil and Transmission Coolers, to dissipate heat by 8% to 10% faster then bare metal while providing excellent corrosion protection.
7. Brake Calipers, to provide heat dissipation, corrosion protection resulting in longer life.
These are just some of the applications of Gun Kote. You are limited only by your imagination!
