the 650 buildup of sara
- kawsakiman
14 Nov 2007 09:54
well i finally gathered everything i needed to hop sara up a little.
i will be posting new pictures as i go along.
these are just a couple to get me started and so i don't forget to take pictures as i do this.
this one is of the poor girl missing her upper half.
- kawsakiman
Re: the 650 buildup of sara
14 Nov 2007 09:56
i forgot to take a picture of her before ripping her apart but there is one in the gallery and in my profile.
now for a close up of the engine minus the upper end.
- kawsakiman
14 Nov 2007 09:59
she did sit for a year so i know some parts are getting rusty. all will be taken care of.
now for the head.
it was done by super bike mike 20 years ago and i picked it up for $150!
i stripped a gpz750 head for the valves and retainers, had ape srpings installed, milled 10 to be sure she was true.
the cams are andrews with .350 lift and .254 duration.
should be a all around good cam.
( i still have the stripped gpz head if anyone needs it)
Post edited by: kawsakiman, at: 2007/11/14 13:00
now for the head.
- kawsakiman
14 Nov 2007 10:04
the bottom side.
if i had it milled anymore it would have effected the seats. they are right at the edge.
the valves are 35mm on the intake and 30mm on the exhaust.
- kawsakiman
14 Nov 2007 10:08
super bike mike did a serious porting job to this head.
the bowels were really opened up and blended.
the intakes measure 33.5mm at the opening.
this is one fricking serious head!
Post edited by: kawsakiman, at: 2007/11/14 13:09
- kawsakiman
14 Nov 2007 10:13
this is the best close up i have of the intakes.
damm camera flash ruins the pictures.
comming later are the pictures of the pistons for her.
i left them in the trunk of my car and the wife has my car today because hers is in the shop.
- scumbag
- Lewd, Screwed, and Tattooed
- kawsakiman
- kawsakiman
- hardr0ck68
- Who put the what in the where?
14 Nov 2007 13:56
You say you have a GPZ head laying around do ya? That would be a fun thing to add to my stockpile of futhure build parts...
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- SLEEPER650
14 Nov 2007 14:32
How much did he charge you to put the valves in and cut the head?
78 650sr my baby
78 650sr waiting for rebuild
82 kz1100
82 kz1100
- kawsakiman
14 Nov 2007 16:56
$300 for the competition valve job, milling and assembly.
i had all my own parts.
springs, retainers, valves etc..
he also did my j-head for me.
same work but also cleared it for the larger cams.
the 650 head was ported when i got it and the guy tells me it was almost $2000 20 years ago.
ran into a little stumbling block today, i forgot i need to have my upper case bored so i had to pull the whole motor today.
i might just use the kz crank in the gpz cases i have.
time will tell.
i'll keep the board posted.
time will tell.
