New Old Bike
- Zeo
Re: New Old Bike
11 Jul 2007 15:39
Ok well I got some fuel into it but it looks like my lines are clogged. I pulled the tank and there was a lil bit of crap in there and I got it out. I'm going to repalce the fuel lines but where are the carb jets and all the other things that I might want to clean in the fuel system
- harm
- Tom
Re: New Old Bike
11 Jul 2007 16:42
You will need to remove the carbs. All 4 come off as a set. On the bottom of each carb there are 4 screws that hold on the bowls. Once you get those off you will see the floats, main jets(in the middle), pilot jets(small ones next to the mains). Take all of these out and clean them good. Make sure you can see thru them. Whith the bowls off use some compressed air to blow thru the passagways. You will need a fairly small straight slot screwdriver to remove the pilots.
Hope this helps
Post edited by: harm, at: 2007/07/11 19:44
Hope this helps
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
- Zeo
Re: New Old Bike
15 Jul 2007 13:10
HELP I got it to fire but as soon as it started runnung i GOT A HUGE PUDDLE OF OIL what should I do
- Powder Keg
Re: New Old Bike
15 Jul 2007 15:12
Where was the oil coming from? You might just have a bad seal? The case might be cracked from a po dropping it?
- Zeo
Re: New Old Bike
15 Jul 2007 15:52
it was a bad seal it runs like a champ now but my clutch is not disengaging and my front brake doesn;t work and my tack still doesn't read and I need a front left blinker
- Snakebyte
Re: New Old Bike
16 Jul 2007 04:41
Unscrew the cable from the back of the tack and see if it is turning while the engine is running. If it is not then you might have a broken cable or bad worm gear on the cam.
Do you feel resistance on the clutch lever?
The front brakes can take some time to bleed, patience is the key. best way I found is to crack loose the bleeders and run a hose from the bleeders to a bottle of brake fluid and keep feeding fluid as you pump the brakes.
- Zeo
Re: New Old Bike
16 Jul 2007 14:46
The Clutch lets off some but the tire won;t spin freely. I know its a wet clutch do I just need to run it for a while. I've ajusted it out all the way but it dosen't seem to help
- harm
- Tom
Re: New Old Bike
16 Jul 2007 18:41
If the clutch is stuck and won't disengage it may be from sitting. What i have done in the past is while the bike is idling with the brakes on pull in the clutch and put it in gear. If the clutch is stuck it may lunge forward a little and stall the motor. You need to make sure you are pulling in the front brake and using the back brake. It may take 2-3 times before it frees up.
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
- Snakebyte
Re: New Old Bike
17 Jul 2007 04:32
The safest way is to have the engine off and put it in second gear, pull the clutch in and roll it back and forth. You could also when the engine is off pull the clutch in and kickit over with the kick start, that will loosen the clutch pack. Before I start the engine I ALWAYS do that.
- Wildh2oskier
Re: New Old Bike
22 Jul 2007 14:35
Biquetoast wrote:
He left off buy some clubmans and a little windscreen.
Snakebyte wrote:...Sorry just a littlte humor...
That is the funniest monologue I've read in a while.
Welcome, Zeo.
:whistle: :laugh:
