External Top Oiler Experiment
- tuxedotito
Re: External Top Oiler Experiment
26 Jun 2007 18:45
1981 GPz1100, Wiseco 1170 Kit, BS34 carbs; #40 Pilot and #140 Main, UNI Filters, APE main and cylinder studs, DYNA S, DYNA Coils, and lots of hours. Working towards Megasquirt/Turbo one day!!!
Ft. Lauderdale, FL
Ft. Lauderdale, FL
- tuxedotito
26 Jun 2007 18:47
Ft. Lauderdale, FL
Ft. Lauderdale, FL
- tuxedotito
26 Jun 2007 18:50
Ft. Lauderdale, FL
Ft. Lauderdale, FL
- tuxedotito
26 Jun 2007 18:56
Ft. Lauderdale, FL
Ft. Lauderdale, FL
- tuxedotito
26 Jun 2007 19:00
Ft. Lauderdale, FL
Ft. Lauderdale, FL
- tuxedotito
26 Jun 2007 19:10
I am so embarrased about the dust!!!! The cases are fresh flat black and the block is three coats of pre-baked Harley Black. I know, I know; the machine shop did it and it really does look pretty nice!
All aluminum is straight "Speed-Bead" blasted and clearcoat.
Post edited by: tuxedotito, at: 2007/06/27 07:36
Ft. Lauderdale, FL
Ft. Lauderdale, FL
- tuxedotito
26 Jun 2007 19:12
Ft. Lauderdale, FL
Ft. Lauderdale, FL
- tuxedotito
26 Jun 2007 19:18
Hope you guys don't mind the flood of pics! I took a shitload of them:lol: :lol: Probably sounds nerdy but I feel like I'm making a documentary or something:huh: :huh:
Post edited by: tuxedotito, at: 2007/06/27 07:40
Ft. Lauderdale, FL
Ft. Lauderdale, FL
- tuxedotito
26 Jun 2007 19:22
Ft. Lauderdale, FL
Ft. Lauderdale, FL
- tuxedotito
26 Jun 2007 19:26
If you noticed, I only had enough steel fittings to do the right side. I can't wait until the Summit fittings come!:woohoo: :woohoo:
Ft. Lauderdale, FL
Ft. Lauderdale, FL
- tuxedotito
26 Jun 2007 19:33
Ft. Lauderdale, FL
Ft. Lauderdale, FL
- tuxedotito
26 Jun 2007 19:40
As part of the oiling system, I took some pics of my hand-fabbed cooling fan frame/cooler mount. It is just loosly mounted right now. The mount is located so that the header pipes curve out and down just under the bottom Aluminum Angle like it was almost factory.
Ft. Lauderdale, FL
Ft. Lauderdale, FL
