Voodoosoup's 78' KZ 650 makeover.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: Voodoosoup's 78' KZ 650 makeover.
19 Oct 2007 10:04
#177076
what tools and or technique did you use to shape your seat?i got got some lazyboys for a couple of my kz900's i would like to reshape.
  • TheDevilZX
  • TheDevilZX's Avatar
Re: Voodoosoup's 78' KZ 650 makeover. (New seat pics)
21 Oct 2007 16:59
#177432
Where did you get the dual head lamps like that? And the windshield?
  • OutlawGPz
  • OutlawGPz's Avatar
21 Oct 2007 17:33
#177446
The headlights came off of a Buell lightning i believe..possably a CityX model...
  • TheDevilZX
21 Oct 2007 18:26
#177457
I'd really like to know where to get that windshield and light assembly for my GFS, I've been wanting to convert it from single to dual light assembly.
  • OutlawGPz
23 Oct 2007 06:17
#177760
Go searching on ebay for Buell lightning parts
  • freebyrd24
  • freebyrd24's Avatar
07 Nov 2007 07:29
#179955
How did you get that killer gauge to work and be able to use all those functions on your bike? I love that gauge you picked up :woohoo:
- 1981 KZ1000-K1 LTD - Long term project
1075cc Kit - New Wiseco Pistons
Sold:
- 1978 kz650 SR, 4-1 Vance and Hines Full Exhaust, Dyna-S Ignition, Accel Coils and Wires
  • Zedone
  • Zedone's Avatar
13 Nov 2007 05:17
#180821
Hey Voodoo, WICKED JOB!!!! Everything really came together nice. Regards, Doug B)
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
  • Voodoosoup
  • Voodoosoup's Avatar Topic Author
29 Jan 2008 08:17
#191614
OutlawGPz wrote:
Looks great man!...What is the tail off of if you dont mind me asking? After seeing this thing take form im def inspired to play around with my GPz. Also what year of Buell did the headlights come from and what was all needed to adapt them to the bike?
The tail is the stock ducktail from the kz650 with the inner fender stuff removed and a taillight from a 85 or 86 zx6. I stole that idea from anther member Mark Wing.
Here is a link to the info I used for the Buell conversion. It has all the part numbers and electrical connection info that you need.
tinyurl.com/2wkuqt
They've discontinued the older, cheaper ($50) dual headlight unit and changed the part number and cost. I think it's over $125 for the light alone. I lucked out, my local Harley dealer gave me 3 other dealerships to contact about the older headlight. The last one I called had 1 in stock! Tee flyscreen is still a current production item and should be available in several colors.
Post edited by: Voodoosoup, at: 2008/01/29 11:23
  • Voodoosoup
29 Jan 2008 08:21
#191615
I simply used a sharpie to outline the shape I wanted to cut and used an electric carving knife to cut and shape the foam. It worked great!
  • Voodoosoup
29 Jan 2008 08:26
#191617
Thanks, it simply wires up to all of the indicators that were on the original set of gauges. The only one that I haven't been able to make work is the stop/brake indicator.
The speedo is driven off of a sensor mounted on the fork and a magnet on the brake rotor. The tach has a sensor wire that connects to one of the coils.
  • Voodoosoup
29 Jan 2008 08:28
#191618
Got my swingarm last week as well. $90usd shipped :D
Here's my original tank, I had it blasted last fall.
Post edited by: Voodoosoup, at: 2008/01/29 11:30
Post edited by: Voodoosoup, at: 2008/01/29 11:34
  • Voodoosoup
29 Jan 2008 08:42
#191621
New rear wheel. 16x3.5 off of an 86' zx1000.
I took off the exhaust last night. I wanted to change out the flanges but they don't appear to be removable.
The end of the header tube is flared and instead of two clips that sit around the end of the pipe like every other 650 exhaust, these are one piece! I wanted to get this blasted and ceramic coated, I'll have to check to see if they still can.
I yanked the carbs as well, in preparation for removing the head and jugs. Had to survey all of my oil leaks. A full gasket kit is on the way!
