KZ650 CSR modifications anyone?
  • Pacificmonarch
  • Pacificmonarch's Avatar Topic Author
Re: KZ650 CSR modifications anyone?
03 May 2007 17:08
#136892
I would like to drop the front end a bit. I want to get the most performance out of my CSR. If possible I don't want to machine anything(because I don't have any money!) for now. What other fork can I directly swap other then '77 KZ560(also around how much would the '77kz560 cost for the whole front end?)? Are there any later model bikes I can swap the fork with?
  • Muddy
  • Muddy's Avatar
04 May 2007 04:56
#136983
How much do you want to drop it? You could just move up the forks in the triples to drop an inch or so. If money is short, that will drop it a bit and then you can swap the front end later. I couldn't do this on my project as the forks that came on the bike where from a kz750 or 1000 and where probably at least 3 inches longer than stock. It also had a mag wheel and daul rotors which I didn't want.
Swapping the front end invloves forks, wheel, speedo pickup, rotors. The only down side to moving the tubes up in the triples is they look a little funky sticking up above the triples. But doing this would save you some cash to start looking at pod filters 4 into 1 exhaust and re-jetting.
As far as swapping pretty much any kawi 36 mm fork will slide into the triples. you just have to watch you don't go too short in length or you'll have clearance problems. But as said above if you move from leading axle forks to conventional you are looking at wheel, rotos, axle, speedo pickup.
  • krcrawford29
  • krcrawford29's Avatar
23 Jan 2008 11:31
#190662
CSR riders, I dug up this old post to see if you were still around. I was just wanting to see other peoples rides and get some ideas.
thanks ;)
  • jbalet666
  • jbalet666's Avatar
21 Jan 2013 15:17
#568516
hey just purchased an 82' KZ650 csr with sole intentions of doing a cafe racer
im sure the older posts have been addressed but
im looking into swapping out my fork and i know that the head tube angle and everything else on the bike (frame,motor,rear suspension etc.) are all the same from other KZ models and was curious as to what anyone else is doing in regards to swapping out the front forks?
81 650csr
AoA
old soul young blood
21 Jan 2013 20:08
#568558
jbalet666 wrote: hey just purchased an 82' KZ650 csr with sole intentions of doing a cafe racer
Wow! That's good to know. Don't tell the KZ1000 guys that my KZ650 has the same motor as theirs. :whistle:
  • jbalet666
22 Jan 2013 11:58
#568645
Haha I should have specified I meant regarding other kz650 models
I was just hoping to be able to swap forks with another kz650 and check to make sure my research was correct
81 650csr
AoA
22 Jan 2013 12:21
#568648
Actually you will find that there are lots of differences even between KZ650 models. Charging systems, harnesses, forks, swingarms, brakes, etc. vary between different years and models. You may want to check the parts diagrams at Kawasaki.com to see what matches and what's different. That's a pretty good resource, although it has some errors. Ed
22 Jan 2013 13:47
#568658
Lots of good info on kawasaki.com, including parts diagrams, part names, part numbers, models sharing same part, availability, etc. Here's a link for help with navigating the site and finding information.
Click > kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
Good Fortune! :)
  • jbalet666
22 Jan 2013 14:47
#568668
Thanks very much I have an aftermarket manual for all 1982 kz650 models but it seems to leave alot of the part sizes /dimensions out
81 650csr
AoA
  • jbalet666
22 Jan 2013 14:59
#568672
Yeah I'm just kind of going off the manual that I have at the moment
I'm only really concerned about my front fork and getting the stance of.a cafe racer simply and preferably without much or at all.possible no machining
81 650csr
AoA
22 Jan 2013 15:07
#568674
jbalet666 wrote: Yeah I'm just kind of going off the manual that I have at the moment
Would bear in mind that dropping the front end by raising the fork tubes inside their clamps will "quicken" the steering, and might cause or aggravate any front end handlebar wobble.
Good Fortune! :)
  • jbalet666
22 Jan 2013 17:35
#568685
Yeah that was my first concern
But isn't that what steering dampers are for?
81 650csr
AoA
