Kz1000j Hotrod
- StreetfighterKz
Re: Kz1000j Hotrod
14 Mar 2007 08:49
Here are a couple aftermarket ones...
www.airtech-streamlining.com/kawiz/ZX7R1993-95.htm (toward the bottom)
www.beasleycomposites.com/racebike_kawasaki.htm
(about middle of page)
www.sharkskinz.com/kawasakizx7r.htm
They're probably more $ than you want to spend, but you don't have to worry about scratches or cracks.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- 77KZ650
Re: Kz1000j Hotrod
14 Mar 2007 22:04
Im in the same boat, looking for one from a 95:(
I have one, but its broken, and a small piece is missing.... I might have to melt/patch/bondo it....
I may regret this if you are an avid ebay hunter, but the fenders from the following bikes are the same. zx7 93, 94, 95 zx7r 93, 94
07 MDP Rookie of the Year
- WISCONSINKZRACER
Re: Kz1000j Hotrod
16 Mar 2007 08:31
thanks for the links, those are cheaper than nos kawasaki fenders at $150.00, they want 80.00 for the aftermarket ones, thats not too bad.
- StreetfighterKz
Re: Kz1000j Hotrod
16 Mar 2007 08:43
N/P
I actually just remembered I have a '94 Zx7 fender, but its cracked and has a few peices missing. If you want I can get a pick, if not I'll just throw it away.
later, Doug
later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- WISCONSINKZRACER
Re: Kz1000j Hotrod
16 Mar 2007 08:56
ill probly order a new one cuz i really need to get this done in limited time, but thanks for the offer
- WISCONSINKZRACER
- WISCONSINKZRACER
- wireman
Re: Kz1000j Hotrod
26 Mar 2007 12:24
that oughta be a riot to ride,you shouldnt have any problems sidestepping clutch at 6,000 just make sure youve got a grip on the bars! :evil:
- WISCONSINKZRACER
Re: Kz1000j Hotrod
26 Mar 2007 22:27
yeah, its prety fun. that stupid header dont seal up very good, its a spring mounted quick release pipe, the exaust leak hiss drives me nuts, might have to get a bolt on pipe just like it to keep my sanity, i tryed to find info on that to see if anyone else had the same problem, but I couldnt find anything:angry:
- guitargeek
Re: Kz1000j Hotrod
26 Mar 2007 23:16
Damn, dude. That's a sweet bike!
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- rattler
Re: Kz1000j Hotrod
27 Mar 2007 22:37
i realy like your set up! long and low the way kz's are ment to be. i have the same pro comp pipe, wish mine would mount up. i dont have enough rake with the front end i am running. i only got about 1/16 inch clearance between the fender and the header
was wondering how much maching work went into the front end. i have a 05 zzr-1200 front end on my kz streetfighter and it took some work....swap stems,had some bushings made and some bearings and i was set. i am just curious because i will be starting on my mkii this year slowly but surely. just got it as a rolling chassis as of yesterday using my old stock parts from my streetfighter.
let us know what kind of times you out down when you get it to the track.
- rattler
Re: Kz1000j Hotrod
27 Mar 2007 22:40
oooo. i forgot to ask what is the seat off of! it gave the bike a real sweet look.
