Kano's Projects Z1000R and KZ1000J's
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: kz1000R2 Eddie Lawson Replica (83)
10 Jan 2009 07:44
#257070
I used a zx12 master cyl. It has a brake light switch built in (I’m sure many modern masters work this way). This allowed me to remove the stock brake light switch. Also u can eliminate the brake line splitter and run the lines directly to the calipers. I would have done that but I already had brand new stainless lines for the stock set up, so I just used them for now.
I have a spare master. and stainless lines now if u are interested.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • kzr750r1
  • kzr750r1's Avatar
10 Jan 2009 10:54 - 10 Jan 2009 10:56
#257086
You are a bad man! Keep up the good work.
Are the legs seated in the intended position or low in the tree for the snapshot? Reason I ask is the usual issue we have with modern legs and wheels lowering the front end so much. One of my thoughts was a top clamp that droped the leg position a bit more to suit our needs.
If I had a clean track on a setup like this it would complete the major parts collection in house then get started on a conversion.
Would be interested if a 750 stem could be spun as opposed to matching the 1000 headstock/bearing kit.
Please keep us in the loop on any future availability and bike progress!
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
Last edit: 10 Jan 2009 10:56 by kzr750r1.
  • kano
  • kano's Avatar Topic Author
  • Not Another Bloody Limey!
03 Feb 2009 14:54 - 03 Feb 2009 14:56
#261983
im in the middle of a hydrolic clutch conversion,
ill post more info at the weekend promise. B)
however in my old age instead of bolting it on and riding off into the sunset i was thinking may be i should replace the clutch as for the life of me i really don't remember the last time i change it or if i ever did?
so it could have been unchanged since 1990 lol. :blink:
when the hydrolic actuator/slave is set in right position and the clutch is worn how bad could it throw things out.
but for now my question is.
buy a Barnett clutch kit.
buy ape springs and separate plates.
if second option what brand clutch.
EBC Clutch Plates?
are there any others worth buying.
Last edit: 03 Feb 2009 14:56 by kano.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
07 Feb 2009 05:43
#262681
Just get a stock set of plates from Z1E. measure the metals for ware and warpage first. u may not need them.
Just stay away from the xtra plate APE set up.They will ware out the basket fingers too fast.
I have a hydro setup mocked up but i have not installed it.
just get yourself a spare clutch rod or 2 (try ebay). if u screw up the length u will have a spare. I supose it would be better to start a 1/8" on the long side and trim down from there.
I charged up my hydro on the bench so i could measure it's travel per stoke of the lever. As the plates ware the piston will sink into the slave.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
07 Feb 2009 06:17
#262685
kano wrote:
once i have the prototype installed i was going to ask him for a price for 5 more sets.
basically its going to be a bolt on busa upgrade for any kz1000 no messing around, well that's the plan lol.
give me a couple of weeks to see whats what and ill see what he says and if he has time.
:whistle: :whistle: :whistle:
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
07 Feb 2009 14:14
#262756
Commin along nicely.
Much better in green too. B)
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
  • kano
08 Feb 2009 16:32
#263036
First things first run into some problems,
This started when I said yeah it will bolt straight on!
So don't say that ok!
When the tree's arrived I looked at them for what seemed hr's lol.
More I looked at them more things I found needed changing.
Stem was fatter at both ends so of course bottom bearing wouldn't
Go on no matter how much I looked at it from my stool while drowning my sorrows with beer.
so I started a list of thing that need to be done and to be honest I knew right there the list was not going to be short.
While the stem was out I asked machinist to drill a hole in the bottom for my new paddock stand to slip into.
then your love this the lower tree's were 1mm to small and the forks wouldn't slide down, so back to the machinist who is always happy to see me by now.
While he was opening up the lower tree's he bored out the billet actuator plate for the zx slave, which needed a little elongating of the holes for the bolts to line up.
Needed a custom axle because the busa front end is wider, had the machinist to make it and requested castleated nuts on both ends.
He did a nice job very happy with his work.
Made a pair of spacers for the front wheel to be dead center which took ages, filing 1mm by hand sucks!
Picked up a cheap set of sidewinder headers just out of curiosity, would allow the deep sump to be installed.
Have to get some spacers made for the rotors to line up with the calipers.
Need brake lines, rear foot pegs, some re wiring, coil mod, fab a bracket for the steering damper.
  • kano
08 Feb 2009 16:33
#263037
more pic's
  • kano
08 Feb 2009 16:33
#263038
more pic's
  • kano
08 Feb 2009 16:34
#263039
more pic's
  • kano
08 Feb 2009 16:35
#263041
more pic's
  • kano
08 Feb 2009 16:35
#263043
more pic's
