New KZ owner in Indiana
- Voodoosoup
I've been here for about a month or so but I didn't have a bike until yesterday, so i didn't have much to post about.
Yesterday, I brought home a 1978 KZ650B, unidentified 4/1 exhaust, not running, painted badly, but in pretty fair condition for the $387.50 I gave for it on ebay. It's got 18,129 miles.
After making some tool purchases today I began tinkering with it in hopes of getting it running. The guy I bought it from had only had it a month before he decided he was in over his head. When I went to pick it up he showed me that the starter would turn the motor over fine, it just wouldn't fire. First things first, I put some gas into the empty tank;). I also discovered that the vacuum line was missing from the fuel control valve to the carb. After I had those things sorted, I made sure I was getting spark. Every few times I would try to kickstart it it was backfiring so I pulled all the plugs and noticed two of them were fouled, they were also NGK9ES instead of NGK7ES plugs that my Clymers says are stock (2 ranges colder). All the Moto dealers were closed by the time I found this out, so I went to Autozone and had them cross reference some plugs that might work. I came home and installed the new plugs and put the choke on full and it started on the first kick!!!:woohoo: :woohoo: Ok, so it's only running on 2 cylinders at this point, but it is running, and that makes me happy. Enough rambling, here are a couple pics of her.
Post edited by: Voodoosoup, at: 2006/09/15 23:21
Post edited by: Voodoosoup, at: 2006/09/15 23:23
- Voodoosoup
- Voodoosoup
- ten6
Michigan City, Indiana
Firefighter MCFD IAFF Local #475
(3) KZ650s (1) 1996 Vulcan 1500A (1) 1978 KZ1000 (1) 1986 Yamaha Radian 600
2000 Dodge Ram 4x4
1960 Chevy Bel-Air
- veerod03
- Voodoosoup
So lessons learned today......
1. You need to have gas in the tank
2. You need to have a vacuum line installed for the fuel valve
3. The plug wires need to go to the correct cylinders
I can see why the guy I got it from gave up after a month.
He really didn't know how to work on/fix anything.
- pumps
- Thank you received: 3
ten6..Hello brother, IAFF local 42 KCFD
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
- fishbone1
- Thank you received: 1
- ten6
Hey Pumps, I got 7 years on so far how bout you? Stay safe out there...
2000 Dodge Ram 4x4
1960 Chevy Bel-Air
- pumps
Post edited by: steell, at: 2007/03/18 09:14
1977 Yamaha XS650
2000 Kaw W650
- rstnick
- Thank you received: 548
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- Voodoosoup
After getting the correct plugs in yesterday, I spent last night and part of this afternoon going through the hacked up wiring, checking and cleaning connections. There were a few wires on the ignition harness that were simply twisted together and wrapped in electrical tape! I took it out of the garage and fired it up, on about half choke it was idling slightly rough, afer some light revving and carb backfires I was able to let it warm up and turn the choke fully off. It was running sweet!!!!!!!!!!!!!!! Here's a new pic.
