- Thank you received: 924
1978 KZ650 - no start
- Warren3200gt
19 Jul 2025 13:51 - 19 Jul 2025 14:01 #914805
by Warren3200gt
Replied by Warren3200gt on topic 1978 KZ650 - no start
Valve lash is 0.08 - 0.18.
Go to the nearest shim that gives you closest to the upper gap size.
Simply the smaller the shim size the larger the vavle gap.
So if your at 0.08 gap with a 255 shim then a 245 shim will give you a 0.18 gap.
Carbs.
If the choke is not helping but it is firing on easy start then simply the engine isn't getting an enriched mixture.
The brass tube pointing down into the bowl is the choke fuel pick up. It has a tiny hole in the end which must be clear as that's where it gets it's fuel through. In the bowl itself there is a hole in the bottom at the back corner. Again it needs to be clear as that's where the bowl feeds fuel to the hole in the choke pick up brass tube.
Either of those two are blocked on each carb and the choke system isn't doing it's job of enriching the mixture and you've virtually no chance of starting from cold.
Both places are often overlooked during a "carb clean"
Carbs.
Last edit: 19 Jul 2025 14:01 by Warren3200gt.
The following user(s) said Thank You: kimchella, BurnsBikesLLC
- BurnsBikesLLC
- Thank you received: 6
19 Jul 2025 14:31 #914806
by BurnsBikesLLC
Replied by BurnsBikesLLC on topic 1978 KZ650 - no start
Perfect, thanks for verifying!
The following user(s) said Thank You: Warren3200gt
- BurnsBikesLLC
28 Jul 2025 08:27 #915167
by BurnsBikesLLC
Just as an update, after setting the valve lash the compression numbers are 125-130
Had to turn the air screw in so it's only 1 turn out, guessing the pods were feeding it more air than expected, but she runs like a top! Thanks for the assistance guys!
