Hi from Poland
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Hi from Poland
13 Dec 2018 02:39
#795066
A user in an other Kawasaki Forum has used Honda Havasu blue metallic B530M, (BG50M-B) on his Z1R.
Looks almost equal to the stardust silver metalic..
www.ksrc-au.com/phpBB3/viewtopic.php?f=31&t=45853&start=15
The following user(s) said Thank You: sebastian81
  • martin_csr
  • martin_csr's Avatar
Re: Hi from Poland
13 Dec 2018 05:53 - 13 Dec 2018 06:27
#795067
Here's a Z1R body set painted in the Honda Havasu Blue.
Last edit: 13 Dec 2018 06:27 by martin_csr.
  • shrap66
  • shrap66's Avatar
Re: Hi from Poland
13 Dec 2018 06:04
#795068
Hello from Canada and welcome. The people here are helpful and will be able to assist you.
Look over your manual carefully and start by doing the basis stuff.
Oil change, oil filter. My bike did not have a filter when I got it :)
Compression test
Brakes
Battery / Charging system / plugs / timing
Check your cables, a lot of the time they are stuck dry and need to be lubed.
Function before beauty
Good luck !
1979 KZ1000B3 LTD Glacier Green
