New z1 900, can any one help identify?
- Natedog13
16 Jul 2017 22:03 #767136
by Natedog13
New z1 900, can any one help identify? was created by Natedog13
Hello! New to the forum and just purchased what I believe to be a 1975 z1 900. I'm new to vintage bikes, and currently own a 2011 Kawasaki z1000 as my daily.
The SN on the bike is z1F 52085 and Z1E 75450, are these too far apart to be matching? Is this indeed a 1975? Another concern is the silver frame and the dual front discs? Kinda lost on this one
The bike is currently not running... I hope I can get her going, it has some interesting mods, especially interesting is the double chain and double sprocket set up.
Any info or opinions would be greatly appreciated !!
- Natedog13
16 Jul 2017 22:07 - 16 Jul 2017 22:10 #767137
by Natedog13
Replied by Natedog13 on topic New z1 900, can any one help identify?
Having trouble adding pictures from my iPad hope this works
Last edit: 16 Jul 2017 22:10 by Natedog13.
- Natedog13
16 Jul 2017 23:10 #767138
by Natedog13
Attachment not found
- Natedog13
16 Jul 2017 23:12 #767139
by Natedog13
- les holt
- Thank you received: 288
17 Jul 2017 05:20 #767150
by les holt
Replied by les holt on topic New z1 900, can any one help identify?
Real Z1 chassis but not a lot else, tank looks KZ, underside weld seam exposed. Front fender is off an Ltd, front forks don't have the reflectors so not Z1, guessing whole front is not original due to dual disc and drilled rotors and wrong master cylinder, Motor #'s too far off to match but the carbs look like the may be correct, hard to tell from the pics for sure, tail section and tail light are correct.
This is not to take away from the bike! It's still a real Z1 and has built in value with that. Ride it, enjoy it and collect parts to put back to original if you so desire.
Les Holt
Les Holt
- Kidkawie
- I bleed premix
- Thank you received: 245
17 Jul 2017 05:26 #767152
by Kidkawie
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Replied by Kidkawie on topic New z1 900, can any one help identify?
The frame is Z1B mfr date July or Aug '74. Engine is Z1B and that number range was used on bikes built in 2/75. Way too far apart to be original.
Also, hard to tell from your photos but there's alot of original parts missing, but it looks like a solid bike. Good luck with it.
1975 Z1 900
2004 KX125
- Natedog13
17 Jul 2017 09:42 #767163
by Natedog13
Thanks for the info guys, was kind of an impulse buy to learn how to work on an older bike, I figured a lot wasn't origional.
I paid 500$ for it do you think I did alright? Just trying to figure out how much money I should actually put in so I don't loose when I go to sell it down the road
- les holt
17 Jul 2017 11:05 #767168
by les holt
You did well!
Les Holt
Les Holt
- Natedog13
17 Jul 2017 11:13 #767169
by Natedog13
THanks! Is there any free manuals available online?
- Thank you received: 2829
17 Jul 2017 11:21 #767170
by 650ed
Replied by 650ed on topic New z1 900, can any one help identify?
Yes, there are some. Take a look at
www.kzrider.com/
. On the right hand side about 2/3 of the way down at that link you'll see a list of manuals that are clickable. Depending on which model frame, engine, etc. you have you might find one or more of them helpful. Ed
- Natedog13
17 Jul 2017 12:15 #767179
by Natedog13
Thank you so much! There is a Z1 shop manual there which is exactly what I need, that's great
- ajsfirehawk
- Thank you received: 89
17 Jul 2017 12:36 #767180
by ajsfirehawk
79 KZ650 SR
80 KZ1000 Z1 Classic
83 KZ1100 LTD
Z900RS
23 Mach 1
Replied by ajsfirehawk on topic New z1 900, can any one help identify?
A bargain no doubt about it. Your stated attitude towards it is perfect. It can be a great deal of fun and unless you get crazy with NOS parts it will likely be worth more than you have in for the duration. Cheers.
79 KZ650 SR
83 KZ1100 LTD
Z900RS
23 Mach 1
