i am new here and am totally lost
  • zelsdad
  • zelsdad's Avatar Topic Author
Re: i am new here and am totally lost
03 Aug 2011 22:56
#466697
excuse my ignorance
my message would not load time after time , then they all loaded with no pic
  • zelsdad
03 Aug 2011 22:59
#466699
it starts well and in neutral it runs fine so i dont think its something basic as i have gone through all the simple things and spent 4 hours labor at a power sports shop with out solution
  • zelsdad
03 Aug 2011 23:01
#466700
as i said i replaced the coils
  • zelsdad
03 Aug 2011 23:03
#466701
i said the bike starts and races in neutral
  • zelsdad
03 Aug 2011 23:05
#466704
same as you , please keep in touch
  • Motor Head
  • Motor Head's Avatar
03 Aug 2011 23:22
#466710
Nice bike there! Wish I could find a beauty like that!
the Fuel Injection system is actually pretty simple, not very many parts to go wrong. But saying that it is not like modern systems with all of the codes to send you nearly directly to the issue. So the old way of testing every componnet is the way to get it right.
The basic problems would be the Throttle Switch, Air leaks, plugged Injectors, low fuel pressure, or a malfunctioning fuel regulator. We found a easy to source replacement for the Throttle Switch, See new_oldkz1000, he has the same bike. he got his straightened out and he last said it was fantastic. I posted a lot of info to help him along, so there is also a Factory Manual in my signature. It will have testing and specs for your Fuel System.
There are several members here who either have the same bike or a lot of experience with the model. me I'm really a Car guy, but have spent like 30 years with the fuel injection, your Jetronic was first around in the early 70's. Alot of Vehicles used the system, but with of course slight mods.
Don't fret you will get it, that bike looks in very good condition. You will probably need to disassemble and clean the fuel system, sending the injectors out for service would be highly recommended, at least by me.
  • shellback1
  • shellback1's Avatar
04 Aug 2011 00:29
#466727
very nice looking bike.
1982 KZ750 LTD
  • zelsdad
08 Sep 2011 21:32
#475233
did you see the fuel pump tear down , there is a micro screen that has been in the inlet since 1979 there are no references to it being inthere and apparently no replacements let me know if this is of interest to you
good luck jerr
  • MFolks
  • MFolks's Avatar
08 Sep 2011 22:53
#475264
A little know fact is the individual injectors have screens, usually in the fuel injector body. One of more may have crud there. Also check the fuel lines. Anything before the pump is low pressure, after the pump, you'll need fuel lines rated to 35-40 PSI.
