New From TX
  • GPz550D1
  • GPz550D1's Avatar
Re: New From TX
18 Jan 2011 18:57
#423411
Here is a new tachometer cable on Ebay or you could buy it locally for a few dollars more. On RonAyers.com, it goes for $22.14.
cgi.ebay.com/ebaymotors/Kawasaki-NOS-KZ5...fPartsQ5fAccessories
1981 KZ550-D1
  • GPz550D1
  • GPz550D1's Avatar
Re: New From TX
18 Jan 2011 19:01
#423412
Here is a aftermarket tachometer cable from Z1 Enterprises.
www.z1enterprises.com/detail.aspx?ID=275
1981 KZ550-D1
  • Hawkeye950
  • Hawkeye950's Avatar Topic Author
Re: New From TX
19 Jan 2011 21:38
#423736
I ordered a new tach cable today. Im ready to have this thing finished and ready to ride to school. Does anyone know if its possible to make the suspension a little bit stiffer? Im 6'6" and 300Lbs. So it rides a little low with me on it.
1982 KZ550-C3 LTD
Re: New From TX
20 Jan 2011 04:32
#423763
If not already done, would check rear shocks' "pre-load" adjustments, as they may now be in a too soft position.
There are usually 5 different settings, ranging from softest minimum pre-load to stiffest maximum pre-load.
Good Fortune! :)
  • GPz550D1
  • GPz550D1's Avatar
Re: New From TX
20 Jan 2011 16:12
#423948
Those rear shocks are a little too soft for us big guys. You can turn the top adjustment collar to #4 and adjust the bottom sleeve to put more pre-load on the spring. Still, mine is soft and I am only 250 lbs.
1981 KZ550-D1
  • Hawkeye950
Re: New From TX
23 Jan 2011 12:25
#424732
They were turned down to 2. I turned them up to 4 and that seems to have helped a lot.
1982 KZ550-C3 LTD
  • Hawkeye950
Re: New From TX
25 Jan 2011 13:08
#425400
I installed the new Tach cable and it seems to be working fine now!
1982 KZ550-C3 LTD
  • GPz550D1
  • GPz550D1's Avatar
Re: New From TX
25 Jan 2011 16:34
#425448
You might consider taking the speedometor cable loose and lubricating the inner cable on it so it won't break like the tach cable. Let us know if you need any more help.
1981 KZ550-D1
  • Hawkeye950
Re: New From TX
13 Feb 2011 10:20
#430414
Well its been a couple of weeks and I havn't had much trouble with it. I have ordered new tires and they should come in this week. My roomate brought his Bandit 1200 up and I drove it. Of course Im drooling over it now haha. Does anyone know if it is possible to take the baffles out of the exhaust? Not really a big deal, but I would like the bike to be a little louder.
1982 KZ550-C3 LTD
