Newbie from NE
- ajspellm
Newbie from NE
12 Mar 2010 22:26
Hey guys,
I bought a 1982 kz550 ltd about a year ago and have been slowly but not successfully fixing it. I bought it running somewhat rough from a guy who had rebuilt the motor. The carbs needed to be rebuilt and synchronized so I bought a synchronizer and rebuilt the carbs. I have been having problems with it not starting though. I think I have the carbs done properly and I can tell it is getting gas but it wont fire. Not sure what else I should be looking at but I am wanting to give up on this project. I want to keep the bike as my expedition doesnt get he best mileage and it is almost riding time out. Any suggestions on what to look at next?
Thanks
Thanks
- testarossa
Re: Newbie from NE
12 Mar 2010 23:04
Time to look at the ignition and electrical system. Remember that you need four things to make an internal combustion engine run. Fuel, air, compression, and spark. You already have air, and assuming that the rebuild was correct, then you should have fuel and compression. Now we need to make sure that the spark is correct.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
- PLUMMEN
Re: Newbie from NE
13 Mar 2010 05:07
have you tuned it up? what part of nebraska are you in?
- N0NB
- Blue handles better
Re: Newbie from NE
13 Mar 2010 06:37
I'll echo Plummen's questions, where at is you exactly? Somebody may be fairly close to you to help out.
A compression test is in order as it's possible that your valve clearances could be getting tight which would hurt starting.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel
- Old Man Rock
Re: Newbie from NE
13 Mar 2010 07:00 - 13 Mar 2010 07:02
Follow the above advise for sure....
If it gets down to the nitty gritty on these KZ550... Loudhvx is the one to PM... They guy just knows these 550's not to mention his knowledge in electrical/electronics is whacked!
Welcome!
OMR
Oh BTW, another Nebraskan (Plummen)... greaaaaaaaaaaat! Quick all, run for the hills :laugh: :laugh: :laugh:
Just n case....
Welcome!
OMR
Just n case....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 13 Mar 2010 07:02 by Old Man Rock.
- Old Man Rock
Re: Newbie from NE
13 Mar 2010 07:04
Ah hell, might as well include this in case you need it....
In your profile signature, add exact date/model and other pertinent info... Will help in future postings...
Again, welcome!
Again, welcome!
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- rstnick
Re: Newbie from NE
13 Mar 2010 07:31
Welcome.
Try swapping the green and black coil wires around. If they are reversed you will still get spark, but at the wrong time. Swapping them wont hurt, and she may just surprise you!
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- ajspellm
Re: Newbie from NE
13 Mar 2010 09:02
I am in Omaha. I thought about checking all that but really had no idea where to being with the spark. I have a haynes manual but didnt have it with me yesterday. I am moving garages today so I was wanting to get it running so I didnt have to push it to the new one lol. It nots very far but still dont want to have to push. I was maybe going to check the plugs today and see how they were as I have had it for a year and have not checked it at all. I will try and check the spark and see whats going on with that. Thanks for the all the help guys. Its nice being on a forum where you dont get yelled at for asking things that have already been asked. People actually help here.
- anarki650
Re: Newbie from NE
13 Mar 2010 09:13
Check your plugs as planned, might just be a fouled plug or two keeping her from starting up. If you find a fouled plug (or more) replace them and keep an eye on them. Might be that you're running a little on the rich side, which will foul the plugs in a hurry, but might just be a carb adjustment to fix.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Omaha NE
- ajspellm
Re: Newbie from NE
13 Mar 2010 09:22
It also ran alright last year but had trouble starting. Then at the end of the riding season I tore the carbs out and pulled everything apart and cleaned it, I could never get it running the same way. Last year I would have problems with it starting and it would always kind of bog down while driving like it was missing or something. I was never real comfortable with it as I was afraid if I shut it down it would not start back up. It also seemed like it would run really hot and the clutch seemed to be slipping. I think I bought a bigger project then I had anticipated.
- anarki650
Re: Newbie from NE
13 Mar 2010 09:35
Don't give up on the girl yet!!!
If you're uncertain about what's wrong follow this checklist and you'll be riding trouble free in no time!
1. Check compression. If your compression is out of whack you'll have a hell of time getting her running right.
2. Check valve clearances. Out of spec valves can mimick carb issues and drive you crazy trying to get them sorted out.
3. Replace plugs, verify timing is accurate (if you have electronic ignition this isn't an issue), and check voltage at the coils (turn key and kill switch on without starting bike, you should have very close to the same voltage at your coil as you do at your battery).
4. Sync carbs and fine tune carb adjustments.
Once you go through these things you should be tearing up the streets in no time!!
09 Kawasaki ER6n
Omaha NE
Omaha NE
- ajspellm
Re: Newbie from NE
13 Mar 2010 21:33
You have any tips on checking the compression? I am going to go buy a gauge tomorrow but am still unclear on what all to do. I think I just hook the gauge up to my cylinder while unscrewing all of the spark plugs but having them against the cylinder so they dont mess the coils up? Or do I just do one at a time and keep the others in while doing this? I am just going to go to harbor freight for my gauge as they have one for like 10 bucks. Will this do?
