81 KZ550C ignition switch info needed
  • 81_KZ550C_MAINE
  • 81_KZ550C_MAINE's Avatar Topic Author
22 May 2007 06:44
#142354
HELP!
In need of a ignition switch for my 81.
Found switch on Ebay, but only list for a 82/83 C3/C4
Was told would work on my 81/C2, DOES ANY ONE KNOW ???
And is ignition switch an inspectable item ?
THANKS !
Edit: Moved to electrical and added description to subject - Nate
Post edited by: N0NB, at: 2007/05/22 10:11
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
Re: 81 KZ550C
22 May 2007 06:59
#142357
As long as it is for a C model it will work there is a difference in the switches between the A model and C model different plug as I recall. I am curious as to what is wrong with your existing switch, lost the key, not operating the electrics, what? If you just need a new key you can take the number stamped on the lock and contact www.key-men.com and for around $20.00 they can cut you a new key. I've used them before with good success. If it is electrical problems you are having you might try taking it apart and cleaning up the contacts.
As to your question about being an inspectable item I'm not sure I understand what you are asking, do you mean like a state motor vehicle inspection?
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
  • 81_KZ550C_MAINE
Re: 81 KZ550C
22 May 2007 07:03
#142358
FAST REPLY....THANKS !!!!!!!!!!!!
I have no existing switch, currently using screwdriver to turn bike on.
So all "C's" should work with each other ?
  • 81_KZ550C_MAINE
Re: 81 KZ550C
22 May 2007 07:09
#142359
And Yes as to the state motor vehcile inspection.
  • N0NB
  • N0NB's Avatar
  • Blue handles better
Re: 81 KZ550C
22 May 2007 07:14
#142362
Since your question is about what will fit, I moved it to the Electrical section. The bonus is that it will be seen in both forums!
Welcome to the asylum and good luck on getting a switch. If it works electrically and you have the number on the key or the original key, then a locksmith may be able to replace the lock cylinder.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel :D )
  • The Gringo
Re: 81 KZ550C
22 May 2007 07:50
#142373
Ok so as I understand it you have a switch but somebody boogered up the lock. In that case pretty much any ignition switch from that same era will work 550, 650 CSR, 750 Ltd you can just take apart the switch you have and add a new lock setup with a key. As to your state inspection question I haven't a clue you will have to call whoever does the inspections and ask them.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
  • 81_KZ550C_MAINE
Re: 81 KZ550C
22 May 2007 11:25
#142454
