How to mount clip-ons? ('76 KZ400) 21 Apr 2024 07:00 #897937
  • ThatYeti
  • ThatYeti's Avatar Topic Author
  • Thank you received: 10
I've only had it a couple of months and have maybe 200 miles on it but other than the throttle having a little 'space' before it'll give you gas, which makes parking lot maneuvers a little harder than they should be, it's run as well as I'd expect. Got it as a running/rougher bike which is fine cause it's my first and I wanted someone like that to learn on anyway.
But what's does FSM mean?
'76 KZ400
How to mount clip-ons? ('76 KZ400) 21 Apr 2024 09:52 #897942
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 393
FSM = Factory Service Manual
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
The following user(s) said Thank You: ThatYeti
How to mount clip-ons? ('76 KZ400) 21 Apr 2024 10:30 #897944
  • ThatYeti
Thanks and ya I downloaded the one posted earlier in the thread but didn't see anything that detailed but will check again.
'76 KZ400
How to mount clip-ons? ('76 KZ400) 21 Apr 2024 10:35 #897945
  • ThatYeti
Doesn't show the part where the ends of the throttle cables clip in unfortunately, and obviously won't address having one missing for some reason but any idea which of the two I should be using with the single cable I've got?
'76 KZ400
How to mount clip-ons? ('76 KZ400) 21 Apr 2024 13:08 #897953
  • ThatYeti
Ok, measured 6.25" from the end of the bar, added some tape and pushed the pin into it once it was in place to make a mark, got it punched, drilled a pilot hole and then a matching 3/16" hole like the stock bars had. All mounted up and had the throttle going crazy after kicking the start a million times. Turns out it was just giving it all the gas. Took it back apart, moved the throttle end piece to the second slot and it's working as it did, will say it doesn't pull back to 'off' throttle as quickly but hopefully that'll fix itself.
Really happy with how the bars look, though I think they're off center by a tiny bit, will have to see if I can sort that out.
'76 KZ400
The following user(s) said Thank You: Rolf1976_KZ900
How to mount clip-ons? ('76 KZ400) 21 Apr 2024 16:28 #897964
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2111
Lots of slop in the throttle before the engine revs up and slowly returns to idle are signs of problems. A throttle cable on the verge of failure could cause both. There could be other causes, but considering the rest of the bike, I’ll bet on this one.
The closing cable is not strictly necessary if everything else works perfectly, but the the possibility of having the throttle stuck wide open in traffic seems like enough reason to spend a few dollars on new cables.
How to mount clip-ons? ('76 KZ400) 21 Apr 2024 16:39 #897965
  • ThatYeti
Ya it's going on the list, already had to replace the tach cable as it felt off and then fell apart.  The remaining throttle cable does look a little spicy at the connection point so I was going to just see about lubing it but probably better of just replacing it.
'76 KZ400
How to mount clip-ons? ('76 KZ400) 22 Apr 2024 10:24 #897978
  • ThatYeti
Couple dumb questions, but how does one replace that cable? Obviously the bar side just comes off with the switch mechanism but what about the other end? Need to pull the tank for access to where it connects to the carbs?
Second, looking on Z1 and seeing a reference to using shorter cables potentially, is that what I need now with the bar change? If so how short? Or how would I measure?
Thanks
'76 KZ400
How to mount clip-ons? ('76 KZ400) 22 Apr 2024 17:58 #897993
  • TexasKZ
  • TexasKZ's Avatar
The cables attach to the carbs in essentially the same was as to the throttle. Yes, the tank needs to come off.
Shorter cables? Maybe. Does the current one seem too long?
Last edit: by TexasKZ.
How to mount clip-ons? ('76 KZ400) 23 Apr 2024 04:22 #898008
  • ThatYeti
Thanks and I'd say the cables could be an inch or two shorter without having a problem.  Could just be that the ones that's on there is old and it seems all the manuvering to get it on the new bars caused it to snap the connection before the metal bend piece that leads into the throttle switch. To be clear the cable didn't snap, just the shroud or whatever you'd call it, and only at the connection point to the metal bend piece.
'76 KZ400
How to mount clip-ons? ('76 KZ400) 06 May 2024 11:31 #898557
  • ThatYeti
Correction, wrong post.
'76 KZ400
Last edit: by ThatYeti.
