sprocket ratio asssistance 06 Sep 2021 13:57 #854920
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2089
Did you check for proper clearance between the new bearings and the cam journals?
sprocket ratio asssistance 06 Sep 2021 15:11 #854928
  • Southpaw
  • Southpaw's Avatar Topic Author
  • Thank you received: 5
No I did not....
sprocket ratio asssistance 06 Sep 2021 15:46 #854930
  • Injected
  • Injected's Avatar
  • Thank you received: 453
You never mentioned if this bike was air shifted, if it has a slick or bar, what RPM your leaving at - These all make a difference at the finish line. As far as the original question I believe most guys are running a 15/36 combo (that's how mine is geared)
Also it sounds like your not hitting it hard enough off the line.
Last edit: by Injected.
sprocket ratio asssistance 06 Sep 2021 17:09 #854933
  • TexasKZ
  • TexasKZ's Avatar
sprocket ratio asssistance 06 Sep 2021 18:22 #854940
  • urankjj
  • urankjj's Avatar
  • Thank you received: 202
If you are hitting the traps @ 97mp, but the bike is still pulling then something is missing. Air box or pods ?... main jet size ?... petcock delivery ?... rider in excess of 300 lb's -(just kidding).  Good Luck to you.....
sprocket ratio asssistance 07 Sep 2021 07:44 #854954
  • Southpaw
HEY,  i,m not an ounce over 270 lbs.!! LOL
sprocket ratio asssistance 07 Sep 2021 07:47 #854955
  • Southpaw
Yes air shift, slick and bar. Im still learning to launch the bike i am not leave hard at all, which im sure are all factors. Now the engine is back out i believe my biggest problem right now is missing horsepower, gotta get that corrected first.
sprocket ratio asssistance 07 Sep 2021 08:23 #854956
  • Injected
  • Injected's Avatar
If you have a slick and bar setup there should be no issue launching at 6K or above, with a small motor you want to keep the RPMs up there.
You said it was a purpose built bike but no mention of a lockup clutch?
sprocket ratio asssistance 12 Sep 2021 15:26 #855182
  • Southpaw
No lock up clutch. Sent the head to FBG for valve job. #3 cylinder was down to 90 psi. Found my horsepower loss. Hopefully back to the track by mid October.
sprocket ratio asssistance 12 Sep 2021 18:22 #855192
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1883
What did you figure out with cam bearings?
sprocket ratio asssistance 13 Sep 2021 02:22 #855201
  • Southpaw
Well the cam bearings. Seems i have two different manufacturers of the bearing mixed together. There is a definite difference in the quality of the bearings. As i recall i had to buy from two different places to get a full set of bearing. Knowing what i know now i would have left the originals in the engine, guess its all part of the learning experience. Best you can do is learn from your mistakes and move forward, I am definitely going to check the clearances when the head gets back from FBG.
sprocket ratio asssistance 01 Nov 2021 02:39 #857248
  • Southpaw
Well,
Got her back to the track last weekend. Did not change the gearing at all. But did put in cam bearings and had a valve job done. First pass i finally broke a 100 mph barely but i broke it. Still not very smooth of a run, so i decided it was time to turn on the autoshift and see if its me or the bike. Well its me. Autoshift made a world of difference, made a few more passes to get the autoshift dialed in last pass of the day i hit 103.44mph. With that straightened out i was able to start paying attention to what the bike is really doing. Found it not shifting into 5th until nearly the finish line so gear change is definitley in order for next year. Gonna be a long winter. Thanks for all the help and words of encouragment!!
