Piston Hole Kz1000LTD 1982 05 May 2024 13:45 #898528
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1922
Hardened shaft ends of an aluminum clutch push rod. The oil seal did wear the aluminum rod fast.
Made some spare prarts push rods out of steel.
Piston Hole Kz1000LTD 1982 06 May 2024 14:54 #898566
  • Kelly E
  • Kelly E's Avatar
  • Online
  • Never Give Up. Never Surrender
  • Thank you received: 313
On one of the forks you probably stacked the short rebound spring in the wrong order. I did it once on my 84' Honda Sabre 700S. It took me a little bit to figure it out.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1981 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
And more
The following user(s) said Thank You: cartal, Wookie58
Piston Hole Kz1000LTD 1982 11 May 2024 16:13 #898899
  • cartal
  • cartal's Avatar Topic Author
  • Away
  • Thank you received: 68
Will give a try to this. I measured both and the short leg is exactly the length Wookie posted.
Thank you!
Piston Hole Kz1000LTD 1982 11 May 2024 17:49 #898902
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1883
As Kelly says, I’d bet you didn’t get the short rebound spring on the damper first, inside the longer fork.
Piston Hole Kz1000LTD 1982 17 May 2024 15:51 #899211
  • cartal
  • Away
Hello fellow kz lovers. I went into it tonight; only to find that the longer hanging fork has no spring in the hydraulic inside the bottle. The little spring (the really short one) is not there.
im starting to worry about my memory capabilities, but I am 100% sure all parts that came out went in again.
so one fork bar has the lower spring; and the other one doesn’t.
any ideas where can I find such spring? I completely stirred every corner of the garage, but it’s not here.
Could a spring from another bike work?
Piston Hole Kz1000LTD 1982 17 May 2024 16:05 #899212
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Thank you received: 1897
Which one are you missing Carlos ? CMNSL have stock of some of them
Piston Hole Kz1000LTD 1982 Yesterday 00:54 #899223
  • cartal
  • Away
The smaller one that goes in the bottom.
seems unavailable. I’m thinking it should not be very different from other forks, so perhaps I can try to find a Vulcan fork spring or similar (just the bottom one, and possibly both legs at the same time so there is no difference).
