Gotsum stuff 20 Apr 2024 18:26 #897923
  • TexasKZ
  • TexasKZ's Avatar Topic Author
  • Thank you received: 2089
The crap i have, Measurements shown are from underneath the head to end of threads.
Isthe 313 hollow?
Gotsum stuff 21 Apr 2024 00:14 #897932
  • asphalt900
  • asphalt900's Avatar
  • Thank you received: 167
All the ones shown, including the 313 are solid.
The following user(s) said Thank You: TexasKZ
Gotsum stuff 22 Apr 2024 18:08 #897994
  • TexasKZ
Wookie58,
If you have a chance, and your axle is 20mm, I would appreciate knowing how long the unthreaded shaft is.
Gotsum stuff 22 Apr 2024 23:47 #898002
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1898
I will be disassembling in a couple of weeks so will let you know
Gotsum stuff 25 Apr 2024 19:22 #898124
  • TexasKZ
Who is currently doing the best head work (porting, valves, etc)?
Gotsum stuff 27 Apr 2024 14:57 #898172
  • TexasKZ
No recommendations?
Gotsum stuff 28 Apr 2024 08:41 #898189
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
  • Thank you received: 315
There's a guy named Mike Rieck over on the SOHC Honda website. I'm pretty sure he works on other makes and I've only heard good things about his work.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1981 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
And more
Gotsum stuff 29 Apr 2024 20:27 #898250
  • TexasKZ
No PSP or APE fans here?
Gotsum stuff 04 May 2024 10:29 #898449
  • Wookie58
  • Wookie58's Avatar
  • Moderator
Wookie58,
345mm total including the head (I machined the head round on mine to take the GSXR end) threaded section is 22mm
Last edit: by Wookie58.
Gotsum stuff 04 May 2024 10:46 #898455
  • TexasKZ
Wookie58,
Thanks. If it is a 22mm axle, it will not work unless I want to have it machined down. Sigh.
Gotsum stuff 04 May 2024 11:07 #898459
  • Wookie58
  • Wookie58's Avatar
  • Moderator
Wookie58,
it is 20mm diameter (22mm is the length of the threaded portion)
Gotsum stuff 04 May 2024 18:52 #898489
  • TexasKZ
Wookie58,
Ahh, my mistake. Looks like that is what I am looking for. Did you say it is from a GSXR600?
