1981 GPz1100 B1 Rstomod / ELR "Tribute" 19 Jan 2024 04:33 #894165
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Thank you received: 1896
That end cap looks "familiar"   but the engraving and press work just takes it to another level
1981 GPz1100 B1 Rstomod / ELR "Tribute" 19 Jan 2024 04:56 #894166
  • howardhb
  • howardhb's Avatar Topic Author
  • God, I trust
  • Thank you received: 444
That certainly is a "familiar" shape Wookie!
Nice turning job, your lathe is "earning its supper"
H.
'81 GPz 550 D1 Click this link: www.kzrider.com/gallery/kz-550/1981-gpz550d1-9094#joomimg
'81 GPz 1100 B1 ELR "Tribute" www.kzrider.com/forum/11-projects/617040-1981-gpz1100-b1-rst
'82 Yamaha YB100 Fizzie
1981 GPz1100 B1 Rstomod / ELR "Tribute" 04 Mar 2024 02:05 #895921
  • howardhb
  • God, I trust
Finally, I've finished the Kerker pipe....
I sand-blasted the chromed outer surface, to ensure good paint adhesion...
To be sure, it is a REAL Kerker...
I had to fabricate a new baffle pipe, to fit inside the end-cap (I had to modify it, to correct the damage that the PO had inflicted on it)
32mm OD, mild steel pipe.
I made 680 drill centre marks, but drilled 520, 4mm holes
I have spray-painted the end-cap and pipe, with Rustoleum Ultra High Heat, satin black paint.
Afterward, I riveted on my "home made" Kerker emblem.
(had to fabricate a new hanger bracket too...)
Installed, it looks the part, and sounds sweeeeet!
H.
Last edit: by howardhb.
1981 GPz1100 B1 Rstomod / ELR "Tribute" 04 Mar 2024 02:30 #895922
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
I take it you don't have a "Custom Chrome" distributor in your part of the world, I bought a meter of pre-drilled tubing for £15
1981 GPz1100 B1 Rstomod / ELR "Tribute" 04 Mar 2024 02:56 #895923
  • howardhb
  • God, I trust
No such luck Wookie!
I used my  lathe to mark out 17 rows and 40 coulmns, then centre-punched 680 drill centre marks ! ! !
However, I ommitted to drill a few rows in the middle area of the tube, thinking it would assist in getting the airflow to go IN at the entrance and OUT at the exit...
The sound is fairly quiet, deep and "throaty" below 5000 rpm...
After 5000 the note changes to a convincing ROAR !
H.
1981 GPz1100 B1 Rstomod / ELR "Tribute" 04 Mar 2024 03:16 #895924
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
That sucks !!
1981 GPz1100 B1 Rstomod / ELR "Tribute" 02 Apr 2024 11:29 #897172
  • howardhb
  • God, I trust
I can hardly believe a whole YEAR has gone by, since finishing the "Tribute" !
(I've ridden close to 10 000km on it already)
Always so satisfying to ride, and brings a smile every time I sling my leg over...
Here she is, in final trim, photographed yesterday evening...
Whatever will be next?....
H.
The following user(s) said Thank You: rstnick, sf4t7, calum, kzMax, Wookie58
1981 GPz1100 B1 Rstomod / ELR "Tribute" 02 Apr 2024 11:47 #897173
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
Looks awesome Howard
1981 GPz1100 B1 Rstomod / ELR "Tribute" 29 Apr 2024 06:44 #898219
  • howardhb
  • God, I trust
Howdy folks!
The fairing mounting brackets that I designed and 3D printed do not do my build justice!
However, they served their purpose, as I could use their dimensions to accurately 3D model new metal brackets, that replicate the OE items!
Here is my design of the Left hand side upper bracket, in METAL...
Having access to a laser cutter and CNC bender at work (and a very generous boss ) make fabrication quite trivial!
Here is the result, welded and painted...
This is the lower mounting bracket, which is screwed onto the brake pipe manifold, under the headlight...
The full set:
Installed:
I used all the anti vibration rubber mounting bits that I printed previously.
Alignment is as good as the original...
⅛" clearance all round (to the headlight)
Big Mamma, and Li'l sis...
What remains now is to paint the wheels gold... sometime in the future!
H.
The following user(s) said Thank You: Vinsky, sf4t7, kzMax, Wookie58, Kelly E
1981 GPz1100 B1 Rstomod / ELR "Tribute" 29 Apr 2024 07:27 #898220
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
Beautiful work as always Howard
