1981 KZ750 LTD four questions 18 Jun 2021 09:44 #850365
  • bluejacobs
  • bluejacobs's Avatar Topic Author
  • Thank you received: 2
Cool thank you! Out of curiousity how did you come up with the add 3T to stock though?
And you said 16T for the front sprocket but then listed a 15T in the second part of your reply. I thought I saw a 39T rear but I may not be looking at the right thing. I'd just call Z1E but their phone number doesn't seem to be listed anymore - sent and email but that may take a while to get back...
1981 Kawasaki KZ750 LTD - running strong but undergoing cosmetic surgery after a crash 4/15/24
1980 KZ750 - 7k on the clock been sitting 30 years - possible donor for 1981
1981 KZ440 A - was running until the end of 2022, sitting in a barn for now
1981 KZ440A - donor bike
1981 KZ750 LTD four questions 18 Jun 2021 14:08 #850375
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2707
My bad on the 15 vs. 16. 16T is correct.  You can check yourself using one of the many sprocket calculators around on the internet.  Compare the "pitch diameter" of a 13T 630 sprocket to a 16T 530 sprocket.  They will be very close in size.
1981 KZ750 LTD four questions 29 Jun 2021 18:42 #850931
  • bluejacobs
Alright crew here's another one - did an oil change on this bike and put in 3qt of 10w40 full synthetic as a starting point so we'd be nice and happy between the low and high fill marks. I've ridden the bike about 40 miles since and the other day went to hop on but checked the oil before taking off the center stand. We were at the bottom of the eyeglass....I'm stumped. Not leaking anywhere under the bike, plugs aren't fouled, although there is a decent amount of carbon on the piston heads (24.8k miles on the clock). I'm wondering if it's valve seals? When I had plugs out I hand spun the engine and there was definitely oil on the seat of the valves that I could see. Thoughts?
Also because it isn't in the manual the I found, and a few people seem to have the same question here is the loading info for the 1981 KZ750 H2 LTD straight off the stem:
GVWR 860 LBS
GAWR FRONT 375 LBS with stock wheel/tire at 25psi
GAWR Rear 562 LBS with stock wheel/tire at 25psi
hope someone else finds this useful! Thanks!
Last edit: by bluejacobs.
1981 KZ750 LTD four questions 29 Jun 2021 19:44 #850935
  • Thank you received: 2829
Only 3 quarts?  No wonder it is low on oil.  Why didn't you put in the correct amount of oil to start with?    Ed
1981 KZ750 LTD four questions 29 Jun 2021 20:03 #850937
  • bluejacobs
Because I'm a cheap bastard and rather than put in 3.5 I put in 3, since that brought it to about the middle of the sight glass, and there's a small chance it's going to all get drained again soon anyways.
1981 KZ750 LTD four questions 29 Jun 2021 20:09 #850938
When changing the oil it is not unusual for the oil in the site glass to be a bit high until the bike's engine has run and been allowed to cool down.  I suggest you put in the correct amount of the correct type oil and then see if the oil level goes down after a ride.  Be sure the oil is JASO-MA compliant.  That should be shown on the oil container's label.  Using the wrong oil can ruin the clutch.  Ed
Last edit: by 650ed.
1981 KZ750 LTD four questions 10 Jul 2021 10:38 #851548
  • bluejacobs
Went to change the fork oil and seals because who knows when it was done last... Photos of the old seals and retainers attached. Yikes.
In my disassembly, there was a part that seemed to be missing but the parts diagram is somewhat unclear. In the service manual it is called the piston ring, and resembles a washer, but in the OEM parts diagram it is part of the piston/cylinder unit. Neither fork had such a ring but each did in fact have a small black ring that fit into the groove at the top of the piston/cylinder.... Are they the same thing?
1981 KZ750 LTD four questions 02 May 2024 04:55 #898334
  • bluejacobs
Almost ten years later, and this thing is still kicking. Two weeks ago, I had my first crash and I was fortunate enough to miss all the boulders on the side of the road and more or less walked away with a lot of severe bruising. The bike definitely took the brunt of it, but all things considered we're looking at mostly cosmetic damage to the bike, but of course it's all the expensive bits like the exhaust, tank, and instrument housings. That being said, I've managed to find another, this time a 1980 KZ750 that's been sitting outside for who knows how long and while some things are roached (seat, tank, mirrors) the bike is in surprisingly overall good condition and with only 7k on the clock and oil in the engine still, it turns freely!
So I'm at an impasse - I can use it as intended as a parts bike to fix "my" bike with 26k on it that I love dearly, or I can swap good parts from my bike to this new project. But that's for mulling over some more later perhaps with a few fingers of bourbon and a campfire. For now, I just want to get back on the road.
That said, looking at part numbers and diagrams most everything should swap fine, but I noticed the gauges on the parts bike are slightly different in terms of what indicator lights are on which pod, as well as the addition of a voltage meter on the tach side of the 1980 not present on my 1981. I know the mechanical tach and speedo will be fine, but am I correct in guessing getting the electronics to work will just be a matter of matching the correct wires to the correct pod? What about that voltage meter?
The other curiosity was the swingarm on my 1981 has no grease fitting which I always thought was odd - the swingarm on the 1980 DOES have one and I was considering swapping them. Is there a reason it was deleted on the 1981 that anyone knows of?
Glad to have found this community and be a part of it.
1981 KZ750 LTD four questions 02 May 2024 10:17 #898368
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1630
Probably cost. 1 less part. 1 less step in the mfg process drilling/tapping the hole. 1 less step in the labor process.
possibly because most riders who have it ignore the thing. ha ha.
Last edit: by martin_csr.
1981 KZ750 LTD four questions 04 May 2024 07:06 #898433
  • Stargate
  • Stargate's Avatar
  • Thank you received: 0
As mentioned, they probably deleted it for cost savings. My 81 1000 LTD didn't come with one either. When I did a frame up resto on it several years ago I saw how bad the swingarm was and installed a zerk fitting in it myself.
1981 KZ1000-K1 LTD
Original owner
Photos
