Hello Guys, Im new to KZRider.
I recently purchased a 1978 Kawasaki KZ650 SR.
She is a solid bike, I have put over 500 miles on her in the month since I have had her titled. I wanted an SR because of the brake setup mainly, and I found this one at a deal I couldn't pass up. The original plan was to do a flat, Scrambler-esque rear end on it, but I have since decided that I would prefer to convert it over and have the Duck tail rear end of the standard KZ650's.
My tank has a few dents in it as well, so I have basically decided to swap all of the body work over.
I need:
Standard KZ650 Tank
Standard KZ650 Seat
Standard KZ650 Duck Tail Bodywork
I'm debating as to whether or not I want to also install the rear under fender that was also on Standard KZ650's, or If I would want to run the tail on by itself. I could put a thin piece of aluminum underneath if I felt like it needed some shielding.
My questions are:
1. will the standard Gas tank snap on, no problem, just like my SR "Coffin" tank?
2. Will I need to weld new tabs/bracketry to bolt on the Standard Duck Tail and seat?
3. Will my Seat Lock, Latch, and prop all still function?
4. Will I still be able to retain my underseat storage pocket and the plastic under fender there?
Lastly,
Would there be any benefits to swapping over to the standard 18" KZ650 rear wheel, or would I be better of with the 16x3 rear wheel that came equipped on my SR? I'm a bit torn on this decision. I like the height of the standard rear wheel, but I also like the thickness of the SR wheel.
Also, if you happen to have any of these items available, I'm definitely hunting for them! I found a few candidates on Ebay also.
Thank you,
Brian
Look forward to chatting with you guys!
Here are a few pics of the old girl, She just clicked over 10,000 miles... time to do the valves and rebuild the carbs!
