Painting mag wheels...
  • racer54
  • Topic Author
11 Aug 2010 18:36 #390195 by racer54
Painting mag wheels... was created by racer54
Have some mag wheels off an LTD I am thinking about painting. Has anyone repainted their mags? What paint did you use? Did you blast the old paint first, rough up in any way or just clean good and paint over the paint already on wheel? Can't see how you could do anything but sand-blast to take old paint off. Not sure what paint to use...gloss...semi-gloss...is there special type paint for this type of use? Ideas...experience...suggestions?
11 Aug 2010 19:37 #390216 by kzbobber1
Replied by kzbobber1 on topic Painting mag wheels...
I paint wheels all the time in my shop. Honestly it is not going to be as strong as powder coat, but if you are looking to do it than you will want to either have them blasted to get the paint off or use Aircraft stripper. It will strip paint easily but not powder coat. You can sand them also but wont really give them the tooth you want to let the paint stick very well. You will also want to use an adhesion promoter like Bull Dog to help the paint stick well. If you plan on doing a rattle can job on them then I would recomend using an engine enamel because they stick better and are a little stronger than regular spray paint. As far as gloss or no gloss that is up to you man. Any more questions feel free to ask. Thanks
11 Aug 2010 20:20 #390233 by T_Dub
Replied by T_Dub on topic Painting mag wheels...
I sandblasted and used duplicolor wheel paint in a spray bomb.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
  • TeK9iNe
  • What did you do!?!
11 Aug 2010 20:24 #390234 by TeK9iNe
Replied by TeK9iNe on topic Painting mag wheels...
Just hand them to a reputable powder coater.
Rattle can garbage just needs re-doing every couple years.
GL.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • racer54
  • Topic Author
12 Aug 2010 17:11 #390433 by racer54
Replied by racer54 on topic Painting mag wheels...
Never thought about powder-coating them. Does that give them a different look then paint? Seems it would be a glossier, smoother look?
12 Aug 2010 18:36 #390469 by MFolks
Replied by MFolks on topic Painting mag wheels...
My understanding is that after spraying the powdercoat, the item is baked at around 350 F. I'd think as long as the wheels are off. this would be a good time for new bearings as the heat from baking might make the lubrication leave the bearing races.
12 Aug 2010 19:13 #390482 by mjg15
Replied by mjg15 on topic Painting mag wheels...
I'm pretty sure any powder coaters will require you to remove the bearings first. the grease would probably run onto the paint
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
12 Aug 2010 19:52 #390498 by donthekawguy
Replied by donthekawguy on topic Painting mag wheels...
I blasted mine and used a semi gloss rattle can that looked like the gold color used on the ELR bikes. I left the tires on and everything. If you do it that way just cover the bearings real good. When you paint brush thick liquid soap on the tires and anything you dont want painted. Paint the wheels and when they dry wash off the soap. DONE!
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • JMKZHI
13 Aug 2010 05:25 - 13 Aug 2010 05:31 #390559 by JMKZHI
Replied by JMKZHI on topic Painting mag wheels...
I used wet/dry sandpaper, brass wire wheels & a dremel. Afterwards the old paint looked kinda faded & there was quite a bit of silver showing through. I wet-sanded & polished the non-painted areas. To "mask" the silver areas prior to painting, I dabbed my finger in wheel bearing grease then lightly patted the raised-unpainted areas to apply a very thin coating. Masking tape was used around the perimeter. I painted the wheels w DupliColor engine enamel (500° ceramic) - there are several blacks to choose from. I used the semi-gloss, but low-gloss might be closer to stock (not sure). When the paint was dry to the touch, I wiped off the greased areas. Afterwards, I baked the wheels in a low-temp oven (wheel bearings removed).
The paint doesn't have any chips yet, but when/if it happens, I don't believe touchups will be a problem. It seems like the wheels would be more forgiving than, say, a fuel tank.
PS: cast alloy wheels don't get ruined by sand blasting?
Last edit: 13 Aug 2010 05:31 by JMKZHI.
13 Aug 2010 06:59 #390586 by csrjoe
Replied by csrjoe on topic Painting mag wheels...
A little off topic, but has anyone chromed their rims.
16 Aug 2010 19:56 #391540 by kzbobber1
Chrome is not cheap!! Unless you know someone you are gonna pay $300 plus per wheel to have them dipped. Powder coating is much cheaper and will look just like they were painted, smooth and shiny. You will look at around 50-100 dollars per wheel to have them stripped and coated. Just let them know if you want flat or gloss.
