  • Page:
  • 1
  • 2
KZ750e1 Fork Oil Change 23 Aug 2015 12:40 #686840
  • Douglas.P
  • Douglas.P's Avatar Topic Author
  • Thank you received: 0
Hi all, I'm trying to change the fork oil of my '80 KZ750 E1 and have run into a snag. I can't get the fork caps off. They're the air assisted kind and I figured they unscrew just like a normal cap, but they aren't budging. Are there any tips or suggestions for removing them?
1980 KZ750e
Re:KZ750e1 Fork Oil Change 23 Aug 2015 13:52 #686853
  • Rustyhama
  • Rustyhama's Avatar
  • Thank you received: 19
I have the same bike. Mine were very tight too. Obviously had not been out for a long time. I think I put them in a vice so I could get a good grip with my large adjustable wrench.
Hama
'82 KZ305-B1 Cafe Racer
'80 Z750E project
www.dotheton.com/forum/index.php?topic=59260.0
Re:KZ750e1 Fork Oil Change 23 Aug 2015 14:23 #686864
  • missionkz
  • missionkz's Avatar
  • Thank you received: 184
Make sure you loosen the top triple tree clamp bolts before you try and loosen the top bolt of the fork! They must be loose or you can't loosen the cap bolt. Keep the bottom triple tree clamp bolts tight!
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Last edit: by missionkz.
Re:KZ750e1 Fork Oil Change 23 Aug 2015 14:26 #686867
  • Thank you received: 2829
+1 !!! I found that out years ago and added that note to my manual. That tip should have been included in the manual for sure! Ed
KZ750e1 Fork Oil Change 23 Aug 2015 14:35 #686871
  • Douglas.P
Thanks guys! I did loosen the top triple tree bolts. Looks like I'll have to put a little more elbow grease into it.
1980 KZ750e
KZ750e1 Fork Oil Change 23 Aug 2015 15:31 #686883
  • missionkz
Douglas.P wrote: Thanks guys! I did loosen the top triple tree bolts. Looks like I'll have to put a little more elbow grease into it.
Make sure you use the correct size tool... you can put a lot force on to those but they can be damaged. Does it have the schraeder valve installed in it?
Bruce
1977 KZ1000A1
KZ750e1 Fork Oil Change 23 Aug 2015 16:21 #686890
  • Douglas.P
I was trying with an adjustable wrench. Would switching to a 22mm flat wrench work better? Is there a better tool to use? I feel like it's harder since the valve is off-centre. I removed the schraeder valve first.
1980 KZ750e
KZ750e1 Fork Oil Change 23 Aug 2015 17:04 #686894
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1624
Forks off bike. I applied heat to the fork caps using a propane torch. and did the same for the bottom allen bolts.
I use a big crescent wrench & a spare triple tree as a clamping device.
If you plan on removing the bottom allen bolts, use a hardened 8mm allen socket or brake caliper socket. a cheap tool might not be up to the job & could ruin the allen bolts.
Last edit: by martin_csr.
KZ750e1 Fork Oil Change 26 Aug 2015 15:08 #687228
  • Douglas.P
Still no luck with this . Not sure why it's being such a pain. These turn the same way as a regular bolt right? Left to loosen?
1980 KZ750e
KZ750e1 Fork Oil Change 26 Aug 2015 15:13 #687229
  • Nessism
  • Nessism's Avatar
  • Away
  • Thank you received: 2680
Counterclockwise to loosen.
KZ750e1 Fork Oil Change 26 Aug 2015 15:18 #687231
  • Douglas.P
Nessism wrote: Counterclockwise to loosen.
Thanks. Glad I'm at least doing that right.
1980 KZ750e
KZ750e1 Fork Oil Change 26 Aug 2015 15:20 #687232
  • missionkz
You might try sliding one at a time out of the clamps and try heat to the tube ... Not the top bolt cap.
Bruce
1977 KZ1000A1
  • Page:
  • 1
  • 2
