Okay sounds like I have some real troubleshooting to do
I have replaced the rear wheel bearings,
Both tires are the same brand (Dunlop arrowmax) not that it guarantees anything.
I will take a look at the forward shocks and look over my pieced together Marcossis in the rear.
(I am trying to find parts for them since my fix will not last)
The piston is pitted bad so it is only a matter of time until it shears my new seals.
The bike has probably been laid down at one point, I recon from driving away on the side stand.
(side stand mounting bracket is tilted upwards so I have my shifter set way high since I am hitting the side stand while downshifting otherwise,)
And lower frame tube seems to have a banana shape as well.
I will take care of the frame when winter hits among other things (the plan is to give her a good overhaul then)
The wheels alignment is set whit a straight ladder, (what we could find at that time that was long enough.)
BTW since I will probably find a lot of broken parts here (if PO has worked on it)
What is considered good upgrades suspension vise?
For example if I find that PO have filled the forks with sand? (I would not get surprised to be honest)
I would rather update the forks than refurbishing the stock ones.
The same goes for everything else on the bike.
The tapered bearings are noted and will probably find its way to my bike
But I would like the numbers on those bearings, (For example a 6302)
Reason being that I have a contact that can get me just about any bearing for dirt cheap if I have the numbers.
Best regards H
