  • Page:
  • 1
  • 2
Upgrade to Font Duals? 18 Aug 2014 21:32 #644412
  • kzdcw
  • kzdcw's Avatar Topic Author
  • 77' KZ1000A
  • Thank you received: 13
77' KZ1000A like to upgrade to dual front disks. Besides additional caliper, would I be able to use little later disk brakes that are slotted from i.e.. 79' LTD 1000? I like the look of slotted brakes but don't the disk diameter of the LTD's or bolt pattern? Any advice would be greatly appreciated !!!
77' KZ1000A
Upgrade to Font Duals? 18 Aug 2014 22:07 #644418
  • PLUMMEN
  • PLUMMEN's Avatar
  • Thank you received: 103
They will bolt right on. :)
Upgrade to Font Duals? 19 Aug 2014 02:42 #644434
  • kzdcw
  • 77' KZ1000A
Plummen, Looks like they would. So I'm assuming the overall width of the disc and the overall height where it bolts to the wheel hub is the same? Now do I need another front wheel hub? Also, still want to use the front brake switch splitter, can I reuse mine and run 2 separate brake lines of the bottom to each caliper?
77' KZ1000A
Upgrade to Font Duals? 19 Aug 2014 07:40 #644448
  • HBKwaka
  • HBKwaka's Avatar
  • Visitor
I bet you could find a KZP with dual fronts pretty cheap. Check out the parting out thread.
kzrider.com/forum/23-for-sale/595364-kz1000-police-parting-out
Upgrade to Font Duals? 19 Aug 2014 07:49 #644450
  • kzdcw
  • 77' KZ1000A
I'm not sure on the bolt pattern or the diameter of the disc's to keep everything in line with my 77'? It appears from the pictures the the brakes have a wide bolt pattern with the mag wheels and that wouldn't work.
77' KZ1000A
Last edit: by kzdcw.
Upgrade to Font Duals? 19 Aug 2014 08:55 #644455
  • PLUMMEN
  • PLUMMEN's Avatar
HBKwaka wrote: I bet you could find a KZP with dual fronts pretty cheap. Check out the parting out thread.
It would have to be a 76-80,sometime after 1980 they switched rotors and other parts. :)
Upgrade to Font Duals? 19 Aug 2014 08:59 #644456
  • PLUMMEN
  • PLUMMEN's Avatar
kzdcw wrote: I'm not sure on the bolt pattern or the diameter of the disc's to keep everything in line with my 77'? It appears from the pictures the the brakes have a wide bolt pattern with the mag wheels and that wouldn't work.
Send a pm to kz10006,he should have everything you need to bolt them to your stock wheels. :)
Upgrade to Font Duals? 19 Aug 2014 11:05 #644465
  • kzdcw
  • 77' KZ1000A
Already have been in contact with Brian. Great person to deal with :)
77' KZ1000A
Upgrade to Font Duals? 19 Aug 2014 11:17 #644466
  • floivanus
  • floivanus's Avatar
  • Thank you received: 116
The police bikes also have beefier forks and a wider front axle, trees etc.
After 81 or so, IIRC, but I never look up police bike parts to be honest
Past; 78 kz1000, 83 kz550
Andrew
Upgrade to Font Duals? 19 Aug 2014 12:17 #644473
  • kzdcw
  • 77' KZ1000A
I'll just probably use a couple of cross drilled rotors of the LTD or something similar. Know Master Cylinder choice. Not sure there ???
77' KZ1000A
Upgrade to Font Duals? 19 Aug 2014 12:26 #644474
  • floivanus
Anything with a 5/8" bore should be good for dual disc setup, can get a new one on ebay for the cost of a rebuild kit typically
Andrew
Upgrade to Font Duals? 19 Aug 2014 12:32 #644475
  • kzdcw
  • 77' KZ1000A
So that means I can my stock 5/8" bore single disc master cylinder off my 77' KZ1000A ? I thought going to dual discs up front you would need a smaller bore Master Cylinder ???
77' KZ1000A
  • Page:
  • 1
  • 2
