Tried and True Swingarm Swaps
- stonemaster
Re: Tried and True Swingarm Swaps
13 Jan 2011 08:21 - 13 Jan 2011 08:27
calvin17d wrote:
here ya go
cgi.ebay.com/ebaymotors/GS1100E-Swingarm...&hash=item2c5a108915
exactly what u need,
those a 80 and 81 's the 82 is what u need 1100 Emy GS1100 searches on ebay are returning black tubed swingarms mostly shaft drive?
here ya go
Last edit: 13 Jan 2011 08:27 by stonemaster.
- badrhino
28 Apr 2011 11:18
Anybody got any new input on newer swingarms with mono shock setups?
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Franken Z!
- bri_con
28 Apr 2011 12:17
I added a 2007 GSXR 600 swing arm to my 84 GPZ 750. I just had to get a sleeve made to take up the space between the pivot on the GSXR and the GPZ pivot bolt. I also added two small spacers to each side. I used a 2007 GSXR 1000 shock with the GPZ knuckle, but had to get longer links to get the ride height correct.
28 Apr 2011 12:34
hey bri_con,do you have a build thread on that badboy?
that is just the kinda bike that gets peoples juices flowing around here.
really nice lookin.
really nice lookin.
- Kidkawie
- I bleed premix
28 Apr 2011 15:15
Is your bike stand stable? lol j/k
Looks nice so far. doesn't look like a hack-job.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- bri_con
28 Apr 2011 15:20
Thanks guys.
I didn't have any tires at that point and it was just mocked up. I have it mostly together now but still need to do a lot of paint and body work. I am actually hoping to get some electrical work done this weekend and take it out for the first time. I have a build thread here:
www.customfighters.com/forums/showthread.php?t=44264
The following user(s) said Thank You: badrhino
- badrhino
29 Apr 2011 01:15 - 29 Apr 2011 01:27
@bri_con
Now that's what I'm talking about!:woohoo:
I have s swinger and shock from an 07-08 gsxr600 so i'll definitely read your thread for the details if you don't mind.
Could you please make a thread on your build on this site. Also could you go more in depth on the front & rear suspension. More pics too please!
This is almost exactly what I want to do to my KZ1000 suspension wise. Thanks
Franken Z!
Franken Z!
Last edit: 29 Apr 2011 01:27 by badrhino.
- bri_con
09 May 2011 09:58
I have a bunch of parts off the bike if anyone is looking...ending tonight.
motors.shop.ebay.com/bryce_harper/m.html?_trksid=p4340.l2562
- kawasakispeedin
09 May 2011 14:18bri_con wrote: I have a bunch of parts off the bike if anyone is looking...ending tonight.
really nice rims/tires! i wonder if they would fit on my 80kz1000? i bought a gs1100 swingarm and am looking for an 18in rear rim with a 150 tire and i really dont like the look of the 19in rim up front. has anyone swapped the front rim/tire with the stock forks/fender?
Attachment newshocks1.jpg not found
-1980 Kz1000 ltd (current)
-1993 Suzuki GSX600F
-2006 ZZR600 (past)
-1981 GPz550 (past)
-2006 ZZR600 (past)
-1981 GPz550 (past)
- doped304
09 May 2011 17:20
Not to hijack but I have a 78 650C2 with a GS1100e swingarm. I am having a hard time finding the correct wheel bearings. I know I need 20mm bearings from a 1000 but there are so many to choose from. Any idea what model KZ1000 bearings I need. I am running a stock mag wheel.
- INSANEBA
27 May 2014 12:08
I'm actually fabbing up a hayabusa rear suspension to mine. I had Evilswingarms.com build me an arm to same specs as my busa, and that is what will go on at final assembly. I love the mono shock, cleans the side of the bike up big time! I know my swap isint bolt on, but with a steel frame who cares! lol.
Vanilla Gorilla Racing
2002 Hayabusa: Nitrous assisted dragbike/streetbike
2006 GSXR 1000 n/a Streetbike/dragbike
2003 GSXR 600 Pink Streetbike/Twisty Tamer
1977 KZX1000R Hybrid KZ650-GSXR 1000 project in the works.
- mtyquinn
30 May 2014 07:15
I am building a 81 KZ and i have the swing arm off a 06 ZZR600 little spacer work and sleeve for bolt and is perfect. i was able to put the rear ZX14R wheel in it and gound D&G chassies to get a offset sprocket and has a bearing support will have a build thread up soon want to get some progress before i post. Also doing a ZX14R forks and brakes so excited.
