Tried and True Swingarm Swaps 08 May 2010 13:34 #366493
  • hocbj23
  • hocbj23's Avatar
  • Visitor
On the GS1100 swap,u will need to shim the sprocket side to ensure proper chain aligment.Also the Kawi shocks will not fit as the GS arm requires a clevis mount for the shocks,so buy the GS shocks as well.Also,the GS chainguard is needed if ur going to run one.Kawi is too short by about 2 inches..bj
Tried and True Swingarm Swaps 08 May 2010 14:01 #366500
  • otakar
  • otakar's Avatar
  • Thank you received: 29
Here is my GS1100 swing arm adaptation to a GPz. I used shocks made for a gold wing to bring the rear up to where it should be.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Tried and True Swingarm Swaps 10 Jan 2011 17:58 #421332
  • calvin17d
  • calvin17d's Avatar
  • Thank you received: 1
What years on the GS1100 Swap?
1976 Kz900 A4
Tried and True Swingarm Swaps 10 Jan 2011 18:13 #421336
  • hocbj23
  • hocbj23's Avatar
  • Visitor
I used a 1982 GS1000 arm to swap to my 1982 KZ.Replaced the bearings and thrust washers,shimmed the drive sprocket side,used GS shocks and chain guard.Took about 3-4 hours-fairly straightforward.Looks identical to Otakars swap except I retained the rear pegs.Probably any of the Gs arms will work up thru the mid to late 80s.bj
Tried and True Swingarm Swaps 10 Jan 2011 18:29 #421338
  • gearheadmm
  • gearheadmm's Avatar
  • MUCH MORE BOOST..........I mean BRAVO
  • Thank you received: 11
badrhino that avitar is AWSOME! Check out prodjects/80 KZ 1000 ST recycled thread where I show my buddys bike with the 84 ninja 750 mono setup. These are really pretty cool, not much welding. Very similar to the 900 ninja in the shaft frame. Again AWSOME!
General Joeseph Dunford FOR PRESIDENT!!!
69.46.28.106/forum/11-projects/413221-80-kz-1000-st-recycled
Tried and True Swingarm Swaps 11 Jan 2011 11:14 #421498
  • stonemaster
  • stonemaster's Avatar
  • Visitor
I got a 82 for mine, picked it up used from a member over at GSresoure site, 100 bucks
Tried and True Swingarm Swaps 13 Jan 2011 05:41 #421823
  • calvin17d
my GS1100 searches on ebay are returning black tubed swingarms mostly shaft drive?
1976 Kz900 A4
Tried and True Swingarm Swaps 13 Jan 2011 07:16 #421832
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
  • Thank you received: 303
GS1100E will get you what you desire :)
Michael
Alvin, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Tried and True Swingarm Swaps 13 Jan 2011 08:21 #421836
  • stonemaster
  • Visitor
those a 80 and 81 's the 82 is what u need 1100 E
here ya go
cgi.ebay.com/ebaymotors/GS1100E-Swingarm...&hash=item2c5a108915
exactly what u need,
Last edit: by stonemaster.
Tried and True Swingarm Swaps 28 Apr 2011 11:18 #447533
  • badrhino
  • badrhino's Avatar Topic Author
  • Thank you received: 6
Anybody got any new input on newer swingarms with mono shock setups?
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Tried and True Swingarm Swaps 28 Apr 2011 12:17 #447544
  • bri_con
  • bri_con's Avatar
I added a 2007 GSXR 600 swing arm to my 84 GPZ 750. I just had to get a sleeve made to take up the space between the pivot on the GSXR and the GPZ pivot bolt. I also added two small spacers to each side. I used a 2007 GSXR 1000 shock with the GPZ knuckle, but had to get longer links to get the ride height correct.
Tried and True Swingarm Swaps 28 Apr 2011 12:34 #447549
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Thank you received: 797
hey bri_con,do you have a build thread on that badboy?
that is just the kinda bike that gets peoples juices flowing around here.
really nice lookin.
