  • Page:
  • 1
  • 2
KZ 440 1981 starter 16 Sep 2016 14:20 #742530
  • Thank you received: 2829
martin_csr wrote: What're those rectangular bits that're kinda dangling in the center of the plate?
Those are carbon brushes. Ed
KZ 440 1981 starter 16 Sep 2016 14:21 #742531
Nerdy wrote:
650ed wrote:
twiti wrote: I´m shure, I disasamble it and see the magnet broken.
Is the original starter MITSUBA SM-8203
Below is a link to a rebuild kit for the MITSUBA SM-8203 starter. I do not see any magnets; do you? Ed
I'm not sure what you're trying to say here. There won't be any magnets in a rebuild kit: the magnets are permanent parts of an electric motor and are generally epoxied or similar to the inside of the motor housing. They are not intended to be replaceable.
If the OP has a broken magnet in his starter motor I think the only practical option is to replace the motor itself.
Exactly. The magnets are not part of the rebuild kit and are (to my knowledge) not available as separate parts for rebuilding starters. Ed
Last edit: by 650ed.
KZ 440 1981 starter 16 Sep 2016 14:42 #742536
  • twiti
  • twiti's Avatar Topic Author
  • Thank you received: 0
Yep! but 250USD, is too much for my budget. You know some replace?
I´ so in Ali baba some chineses manufacturing who have magnet in arc shape for motrcycle starter.
KZ 440 1981 starter 16 Sep 2016 20:44 #742577
  • Nebr_Rex
  • Nebr_Rex's Avatar
  • Thank you received: 298
The best suggestion I have for you is to get another starter and take the best parts of the 2 to make 1 good starter.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
KZ 440 1981 starter 17 Sep 2016 13:02 #742625
  • twiti
I think you right, the best is other starter to change parts.
Thanks to everyone for replies.
Regards.
Twiti
KZ 440 1981 starter 17 Sep 2016 19:17 #742675
  • WABBMW
  • WABBMW's Avatar
  • Let The Good Times Roll !
  • Thank you received: 16
My starter quit working, and yes, the brushes were almost completely worn away. I have bought some imported rebuild kits for about $20. on Ebay. Everything was just fine, although the little alignment tab on the plate were off slightly simply meant that I had to file it down and manually align the plate. Otherwise it all works well.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
KZ 440 1981 starter 18 Sep 2016 08:06 #742713
  • twiti
Yes, I saw this kits in ebay, but my problem are the broken magnets.
I thought, what could be another model of Mitsuba starter (other motorcycle brand) work it for KZ 440.
KZ 440 1981 starter 18 Sep 2016 08:32 #742720
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2067
I found this application chart. The formatting is jacked up a bit, but after a quick perusal, I did not see another bike using the SM 8203. Maybe a closer look will reveal one.
nationsautoelectric.com/motorcycleapplication.html
KZ 440 1981 starter 18 Sep 2016 12:45 #742755
  • twiti
you are right, any way is an useful information.
Thanks you!!
KZ 440 1981 starter 28 Oct 2019 01:11 #813145
  • nikevas
  • nikevas's Avatar
Hi, I had the same problem with the starter - a broken magnet. I glued it to the LOCTITE Power Fix Gel and it works perfectly now.
  • Page:
  • 1
  • 2
