Red Dyna plug wires such as these examples from Z1E could be used with either their integrated black caps or with any other caps such as the mentioned NGK caps.
Click here > www.z1enterprises.com/product/DYDW300
The NGK caps likely have a built-in resistor (similar to stock caps), but non-stock caps might or might not have the same resistance as stock caps.
Would be sure the non-stock caps do not have more resistance than stock caps.
As already suggested by others, would install B8ES plugs (non-R).
I enjoy running Dyna solid core plug wires with their integrated non-resistor caps together with B8ES plugs, thereby having zero resistance in the wires, caps and plugs (which, if it's a concern, doesn't suppress ignition noise in radio reception).
