  • Page:
  • 1
Cloch swich 29 Apr 2016 11:34 #723622
  • Willy1803
  • Willy1803's Avatar Topic Author
  • Thank you received: 0
I broke my cloch swich an I replaced it with a button an ever since I did that I turn my light on while the button on the main fuze blows and some time it just looses power like the battery's completely dead
Last edit: by Willy1803.
Cloch swich 29 Apr 2016 11:42 #723623
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2621
I don't understand the question.
Cloch swich 29 Apr 2016 11:47 #723625
  • Willy1803
I keep loosing power to the ignition
Cloch swich 29 Apr 2016 13:59 #723640
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2067
What is a cloch switch and what sort of button does your main fuse have?
We need some clarity and explanation before we can offer help.
Cloch swich 29 Apr 2016 14:26 #723642
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1621
Guessing. he replaced the clutch switch there at the clutch lever with some sort of button switch that now acts as the starter interlock. Now whenever he turns on the headlight while the button switch is turned ON, the main fuse blows. sometimes the fuse doesn't blow but the bike just looses power as if the battery is dead. or maybe none of that. ??? ... :)
Last edit: by martin_csr.
Cloch swich 29 Apr 2016 15:25 #723647
  • TexasKZ
  • TexasKZ's Avatar
Seems like a plausible translation, like you I still don't quite understand what is going on to cause a lack of power to some part if the ignition system and the blown fuse. Hopefully the OP will provide some clarity.
Cloch swich 29 Apr 2016 15:40 #723650
  • Thank you received: 2098
Here's a link to forum search of posts by Willy1803's, in some of which he identifies his bike as a 1977 KZ650-B.
Click here > Sundry posts by Willy1803
Including information about bike year and model is helpful to viewers.
It's easy to put the information in your signature where it shows in all posted messages, past and future.
And the signature may be changed whenever and as often as desired.
If wanting a signature showing information about the bike in posted messages, it's easy to do.
Here's how:
Good Fortune! :)
Last edit: by Patton.
Cloch swich 29 Apr 2016 15:55 #723651
Willy1803 wrote: I broke my cloch swich an I replaced it with a button an ever since I did that I turn my light on while the button on the main fuze blows and some time it just looses power like the battery's completely dead
Willy1803 wrote: I keep loosing power to the ignition
Perhaps a short in the wiring or in a switch or in some other electrical component is causing the battery to fail.
With a good battery, there would be no power in the wiring beyond the blown fuse.
With a completely dead battery there would be no power anywhere in the wiring.
In either case, blown fuse and/or dead battery, there would be no power to the ignition.
Good Fortune! :)
Cloch swich 29 Apr 2016 16:09 #723654
Either of the following links should enable a download of a wiring diagram from KZr's FILEBASE:
Click here > 1977 KZ650-B Wiring Diagram
Or click here > Another KZ650-B1 Wiring Diagram
Good Fortune! :)
Cloch swich 29 Apr 2016 23:21 #723703
  • Willy1803
I figured it out it was a loose fuse which was unexpected
Cloch swich 30 Apr 2016 02:16 #723710
Willy1803 wrote: I figured it out it was a loose fuse which was unexpected
Not at all uncommon in these old girls.
Glad to hear you were able to locate and resolve the problem. :cheer:
Good Fortune! :)
  • Page:
  • 1
