  • Page:
  • 1
  • 2
Gremlins! 26 Sep 2015 16:59 #692067
  • vondikka
  • vondikka's Avatar Topic Author
  • Thank you received: 0
That's right around the range I got in the primary coil. I'm not at the shop right now but post my results.
78 KZ650 C2
76 kz400 D3
Gremlins! 26 Sep 2015 17:07 #692068
  • missionkz
  • missionkz's Avatar
  • Thank you received: 184
Oops I meant secondary is 22Kohms to 24Kohms.... Primary is 4-5 ohms... sorry!!!
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Gremlins! 26 Sep 2015 17:31 #692071
  • rstnick
  • rstnick's Avatar
  • Thank you received: 376
Coil testing:
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Last edit: by rstnick.
Gremlins! 26 Sep 2015 17:54 #692076
  • Barry2
  • Barry2's Avatar
  • Thank you received: 23
Also the trouble with coils is they sit right above a hot engine and on a hot day the little rascals just take it an cook and over the years they just get tired of doing their part when they get hot again, My 76 900 is having that problem right now . Ride for a while and shut it off for five minutes and the first big handful of throttle brings major missing and bucking, as soon as the cool air blows past the coils it straightens up and flys right. Coils are now ordered to go along with new plugs and points which I replaced first.
Other than that all is good and have enjoyed the heck out of it all summer.
1976 KZ900
Gremlins! 27 Sep 2015 16:42 #692217
  • vondikka
The results are in. At the 20k setting, I was getting around 8.0 for the primary and at 200k I was getting around 76.0 for the secondary. Definitely not what the manuals says. Still confused though because when I would attach the tester leads, the ohms would consistently decrease over the duration of contact.
78 KZ650 C2
76 kz400 D3
Last edit: by vondikka.
Gremlins! 27 Sep 2015 16:44 #692218
  • vondikka
I'm running 3ohm Dyna coils which are only about 5 months old
78 KZ650 C2
76 kz400 D3
  • Page:
  • 1
  • 2
