I understand what your saying about the tangs possible pushing the needles off center causing them to leak. But wouldn't bending the float arms defeat my adjustments and put me right back where I started? Never mind ... I get it. But with my luck I'll break the floats off the arms.
Unless their leaking internally, their not overflowing externally. Although ... it is really cold natured. Or possibly so I think. Cold starts it obviously takes a few minutes to warm up. But after it's warm and then sits for 15-20 minutes (still somewhat warm) I have to choke it as if cold to get it started and warm it up again.
Please don't tell me I need to tear everything back apart and wrestle those carbs out AGAIN.
Having the stock air box in the way you know what I have to do to get um out. It's a royal pain in the a$$. Lets just say if I keep having to take um out ... pod filters are looking better all the time.
Speaking of pod filters ... Thing is I like the chromies on the sides of the air box and it filling in the otherwise empty hole where it is. With that in mind and knowing the use of pod filters is a far cry better than the stock air box, I got another box from a fellow member with the intention of modifying the front of it making room for pods to at least partially stick inside of it. I don't really like the sucking sound you hear from the carbs with pods on um so I may even make some extensions putting as much of the pods inside of it as possible. Yes, I know that may defeat some of their performance but not the ease of being able to pull the carbs in which is my objective anyway. Worst case I end up with the same performance as a stock air box.
But who knows? I may not do any of that and hope if I have to pull the carbs again it'll be the last time ... for a while.
