All my points screws are stuck! Need advice.. 16 Dec 2014 16:03 #656210
  • krayneeum
  • krayneeum's Avatar Topic Author
  • Thank you received: 0
Hey all,
So my points are pitted and need replacing. But the PO has stripped all the screws necessary to adjust/remove the points ( PSA: Buy JIS screwdrivers! ) I went to remove the screws to remove the whole assembly and they are totally seized. I figured I'll have to drill them out. But I just realized i could also just drill out the screws for the points and just replace those-- $12 vs $60.
What do you guys think? Do I stand to damage anything trying to drill out the points screws??
Here's how it looks:
Attachment FullSizeRender.jpg not found
All my points screws are stuck! Need advice.. 16 Dec 2014 16:23 #656212
  • TexasKZ
  • TexasKZ's Avatar
  • Online
  • Thank you received: 2076
Have you tried a hammer operated impact driver? I've found that carefully using one will drive the bit into the buggered up screw just enough to get the traction needed to loosen them then finish removing with a screwdriver or pliers.
All my points screws are stuck! Need advice.. 16 Dec 2014 16:44 #656216
  • KZ Rat
  • KZ Rat's Avatar
  • Thank you received: 9
You might be able to break them loose with a fluted extractor socket-trick is finding the right size. Sears sells a small kit with 1/4 drive shank.
1979 ltd 1260 1980 ltd 1075 2005 450x for the desert
All my points screws are stuck! Need advice.. 16 Dec 2014 17:16 #656221
  • jakedude
  • jakedude's Avatar
  • Thank you received: 30
Maybe a dremel tool with a cutting disk to cut or re-cut standard screw driver slots? If you try that you may want to mask things off to control the grit and or have someone hold a vacuum close by as you cut.
The screw heads look rather tall with flat sides in your picture. Can you get a small vice grip pliers on them. You might try that first.
Nothing lasts, nothing is finished, and nothing is perfect.
Last edit: by jakedude.
All my points screws are stuck! Need advice.. 16 Dec 2014 18:20 #656232
  • moneypit
  • moneypit's Avatar
  • Thank you received: 35
I used a dremel tool to make flat sides on two sides and broke it loose with a wrench. If you can find a wrench small enough for those.
2-76 kz900
St Paul MN
All my points screws are stuck! Need advice.. 16 Dec 2014 18:38 #656233
  • kzdcw
  • kzdcw's Avatar
  • 77' KZ1000A
  • Thank you received: 13
Remove the whole point mounting plate from the motorcycle. Lay plate on work bench and saturate screws with mix of Acetone/Trans Fluid. Should be able to break loose screws with downward pressure of screw driver. Had the same problem with mine and this method worked great.
77' KZ1000A
All my points screws are stuck! Need advice.. 16 Dec 2014 20:16 #656244
  • Thank you received: 2829
Don't drill anything. Simply soak the screws for 2 or 3 days with Kroil and they will come out without a problem. No kidding! See link below, and below that is the picture of the product I use. It works! Ed
www.kanolabs.com/penLub.html
Attachment Kroil_2014-12-17.jpg not found
All my points screws are stuck! Need advice.. 16 Dec 2014 23:00 #656250
  • aslsmm
  • aslsmm's Avatar
Vise grips. Done.
73 kawasaki h2
78 kz 650
80 kz 650
1972 suzuki tr750
74 suzuki Titan
Putting deposit on ninja h2
All my points screws are stuck! Need advice.. 17 Dec 2014 03:42 #656259
  • Topper
  • Topper's Avatar
  • Thank you received: 133
What ed said. Kroil or PB blaster will loosen them up.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
All my points screws are stuck! Need advice.. 17 Dec 2014 10:12 #656286
  • krayneeum
These are all good suggestions-- thanks everyone!!
I will try some PB blaster maybe some Kroil. If that doesn't do it, I'll work my up to dremel/drilling the screws.
Might go buy an impact driver as well-- cause any excuse is a good excuse to buy a new tool!
Thanks!
All my points screws are stuck! Need advice.. 17 Dec 2014 10:27 #656288
  • Grumpy Ole Artist
  • Grumpy Ole Artist's Avatar
  • Eschew Obfuscation!
  • Thank you received: 62
BOY!!! Do I know these screws, LOL! take a good close look at your screwdriver tip...It might just be the pics, but it looks to me like a nice appropriately sized, flat bottomed, (not "knife edged") sharp cornered straight blade would STILL back those rascals out....It is DEFINITELY easier to mess with all the point's little nuts/bolts/washers/insulators/, &c....on the bench!!!
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
All my points screws are stuck! Need advice.. 17 Dec 2014 16:50 #656326
  • bountyhunter
  • bountyhunter's Avatar
  • Thank you received: 337
TexasKZ wrote: Have you tried a hammer operated impact driver? I've found that carefully using one will drive the bit into the buggered up screw just enough to get the traction needed to loosen them then finish removing with a screwdriver or pliers.
+1 same thing here.
