  • Page:
  • 1
Headlight off switch! Help 25 Aug 2014 23:55 #645173
  • jmoney05
  • jmoney05's Avatar Topic Author
  • Thank you received: 1
Anybody know why this switch is herer? Is it to bypass the headlamp for easier starts?
And where do I connect the wires ?
Attachment image_2014-08-26.jpg not found
Attachment image_2014-08-26-2.jpg not found
1978 Kz650D
Headlight off switch! Help 26 Aug 2014 04:41 #645179
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1619
Somebody added it, so you'll have to figure it out.
A headlight switch seems like as good a guess as any. :)
Headlight off switch! Help 26 Aug 2014 13:32 #645264
  • MFolks
  • MFolks's Avatar
  • Thank you received: 540
Yep, the wiring's not to Kawasaki specs. The Red bullet connector's a sure sign, along with the "Redneck" switch.
Headlight off switch! Help 26 Aug 2014 22:53 #645322
  • jmoney05
Ok, it was hooked up before I tore apart the wiring harness and didn't think to take pictures like I normally do to help remember how it went back together. I'm guessing to put it in line on the driving light power red/yellow or maybe not hook it up at all!
1978 Kz650D
Re:Re: Headlight off switch! Help 27 Aug 2014 03:24 #645330
  • Tomolu5
  • Tomolu5's Avatar
  • Thank you received: 45
Maybe at some point in the bikes life somebody had extra lights on it??? I wouldn't hook it up, as I can't see any reason to shut the headlight off from more than one place.
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
Re:Re: Headlight off switch! Help 27 Aug 2014 04:56 #645334
  • martin_csr
Many models don't have a headlight switch, so the headlight is always on when the ignition switch is ON. If that's what the toggle is for, one reason for turning off the headlight would be for better starting & there could be a couple of reasons why, such as poor starting or someone installed a capacitor in place of the battery. If the latter, he would need the switch, or if the former, that would be a band aid approach, instead of figuring out why a bike won't easily start.
Last edit: by martin_csr.
Re:Re: Headlight off switch! Help 28 Aug 2014 07:56 #645471
  • jmoney05
My bike has only a toggle for high and low beam, no "off "
1978 Kz650D
Re:Re: Headlight off switch! Help 28 Aug 2014 08:43 #645483
  • martin_csr
Does your left handlebar switch housing have a Hi-Lo headlight switch?
Re:Re: Headlight off switch! Help 28 Aug 2014 14:36 #645512
  • jmoney05
Yes sir.
1978 Kz650D
  • Page:
  • 1
