87 kz1000p wiring harness
  • jokerrecycling
  • Topic Author
06 Jan 2013 20:37 #566143 by jokerrecycling
87 kz1000p wiring harness was created by jokerrecycling
I have an 87 kzp that i am turning into a chopper. my biggest issue is the rat's nest that is the wiring harness. does anyone know if there is an aftermarket wiring harness that eliminates all of the wires for the police equipment?
I will post pictures later.
  • wireman
06 Jan 2013 20:46 #566144 by wireman
Replied by wireman on topic 87 kz1000p wiring harness
Not that im aware of youd be better off mounting the parts youre going to use and building your own harness to fit B)
07 Jan 2013 00:27 #566176 by MFolks
Replied by MFolks on topic 87 kz1000p wiring harness
Use this as a guide to remove unneeded circuits:
www.cyclepsycho.com/kz1000p/kz1000p.html
  • guitargeek
  • Elitist, arrogant, intolerant, self absorbed.
07 Jan 2013 22:09 #566277 by guitargeek
Replied by guitargeek on topic 87 kz1000p wiring harness
I'm gonna use my siren switch for the heated grips. ;-)
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
08 Jan 2013 01:02 #566315 by MFolks
You might need a relay for the higher currents in the grip heaters, as most Kawasaki switches won't carry much amps.
  • guitargeek
08 Jan 2013 04:49 #566338 by guitargeek
MFolks wrote: You might need a relay for the higher currents in the grip heaters, as most Kawasaki switches won't carry much amps.
Yep, relays for everything! WGs coil mod, relay to kill the headlight with the starter switch, relay for the extra driving lights, relay for the phone charger, relay for the heated vest outlet... anywhere there's a hefty current draw. I'm building this bike for maximum reliability, as I intend to ride it around the continent.
08 Jan 2013 05:29 #566342 by mick z1a
Replied by mick z1a on topic 87 kz1000p wiring harness
would it not be easier to adapt a new standard model z1000 harness?
09 Apr 2015 20:28 #667369 by loudhvx
Replied by loudhvx on topic 87 kz1000p wiring harness
testing this
10 Apr 2015 13:33 #667422 by loudhvx
Not sure what happened to the filebase.
Work in progress, but here it is so far.
home.comcast.net/~loudgpz/KawKz1000P.pdf
