Looking for wiring diagrams for kz900 parts
- CasinovaRock23
23 May 2012 10:20 #524241
by CasinovaRock23
-Charles
Looking for wiring diagrams for kz900 parts was created by CasinovaRock23
Hi all,
I am trying to find some info about some parts that my Kz900's previous owner bought from Z1enterprises.com. I was able to find the parts listed on the website but no additional information.
The parts in question are the: Rectifier / Regulator combination unit (RI10-515), the Handlebar Switchblock LH Kawasaki Z1 KZ900 (EM99-68891), and the Handlebar Switchblock RH Kawasaki Z1 KZ900 (EM99-68892).
I was wondering if anyone had any sort of a wiring schematic/installation instructions that went along with these parts? I'm trying to collect as much wiring info as I can so that I can debug/rewire my kz900.
Thanks!
Thanks!
-Charles
- DiamondSkyBlue1000
- Thank you received: 41
23 May 2012 12:35 #524246
by DiamondSkyBlue1000
Replied by DiamondSkyBlue1000 on topic Looking for wiring diagrams for kz900 parts
In the upper right hand corner of this page you will see the word FILEBASE. Click that sucker and it will take you to the file archives. Simply select your year and then model and it should be listed in there.
Oh, and welcome to the madness!
- CasinovaRock23
24 May 2012 08:30 #524462
by CasinovaRock23
-Charles
Replied by CasinovaRock23 on topic Looking for wiring diagrams for kz900 parts
Thanks Diamond. That filebase will certainly be useful, but unfortunately I don't think it has the wiring schematic for the specific parts I mentioned.
I'm sure the handlebar controls are wired pretty much identically to the stock ones, so for that the generic wiring layout will work, but the combined rectifier/regulator gets wired into the system quite a bit differently than when the two are seperate modules...so I am trying to find a diagram that will help me set it up correctly.
Because no brand was listed for the part on the z1enterprises website I am having trouble looking up any detailed information for the regulator.
Any clues anyone?
Any clues anyone?
-Charles
- Motor Head
- Thank you received: 393
24 May 2012 10:15 #524490
by Motor Head
Replied by Motor Head on topic Looking for wiring diagrams for kz900 parts
This is from OMR,(Old Man Rock) so it will be correct.
www.kzrider.com/forum/4-electrical/38975...-test-results#389750
- mark1122
- Keep twisting it
- Thank you received: 109
24 May 2012 18:43 #524571
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Looking for wiring diagrams for kz900 parts
if that doesnt help. call or email,Z1E and they will help u.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- pig9r
25 May 2012 00:23 - 25 May 2012 00:29 #524628
by pig9r
Replied by pig9r on topic Looking for wiring diagrams for kz900 parts
They don't come with any directions. ID the regulator and rectifier and with the wiring diagram you can figure out which plugs go where. I am in the process of restoring a KZ900 from what I can remember off of the top of my head: Remove both the regulator and rectifier. You will need slightly longer screws to mount the new unit under the battery tray. The main plug is color coded (green) and plugs into the center harness. The ground can go either to the block or the seat latch bolt (like the stock setup). The white wire with bullet connector plugs into the double female bullet connector with white/red stripe wire. Nothing plugs into the white plug in the center harness, but I would protect it. And there is an unused ground wire bullet connector also from the rectifier that is no longer used.
I restored my switchblocks but I have read somewhere that the reproduction parts are not plug and play exactly on the KZ900 as the color of the wires with the bullet connectors are not the same. Once again the wiring diagram will help you sort it out.
Last edit: 25 May 2012 00:29 by pig9r.
