No Ohm readings. What am I doing wrong?
  • badrhino
  • badrhino's Avatar Topic Author
Re: No Ohm readings. What am I doing wrong?
22 May 2012 00:02
#523938
Why would they sell these types of wires packaged as they did if you can't splice into them. They came as two wires and you had to cut them in half to make the four.
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
  • DiamondSkyBlue1000
  • DiamondSkyBlue1000's Avatar
22 May 2012 00:09
#523940
My manual says you should see about 1.5 Ohms from small post to small post (these would be the primary posts) and about 13,500 Ohms between the two spark plug wires (these would be the secondary posts). You should also measure these places one at a time using the red lead while the black lead is on the coil core which is the piece that mounts the coil to the bike's frame. Those readings should be infinite Ohms.
  • badrhino
22 May 2012 02:22
#523966
Any more input on these suppression core wires? Has anyone else used the splicers with these wires? Should I call Z1E and ask them?
Franken Z!
  • Motor Head
  • Motor Head's Avatar
22 May 2012 10:27
#524001
Personally I wouldn't put any money into those splicers and old coils. As far as suppression wires, on stock coils, make sure you don't have a resistor cap as well, it will really lower the spark voltage.
the Emgo coils are pretty reasonable to buy and are a good stock replacement.
22 May 2012 10:42
#524003
badrhino wrote: Why would they sell these types of wires packaged as they did if you can't splice into them. They came as two wires and you had to cut them in half to make the four.
Would remove splicers and re-test resistance in secondary winding by measuring ohms with meter probes touching wire cores at ends of stubs from coil.
Then refit just one splicer and re-test.
Then re-fit the other splicer, and re-test.
This testing should show whether one of the splicers is affecting resistance through the secondary wiring.
Good Fortune! :)
22 May 2012 11:13
#524011
badrhino wrote: ...was still not getting any readings at the plug caps. I unscrewed one end of the splicer and tested from the splicer on both coils and got readings. Below is what the readings were. Are these in spec.?
Left Coil
Primary 1.9 ohms
Secondary (at splice) 15,100 ohms
Right Coil
Primary 1.7 ohms
Secondary (at splice) 15,800 ohms
Now my question is.....why am I not getting anything past the splicer? These are new wires.
These readings look okay, because the coils seem very comparable to each other.
Could be mistaken, but thinking it's okay to use the splicer for connecting solid-core wire (from coil) to new resistor-style wire. Am seeing nothing to indicate otherwise in NGK's website where the splicer is described.
However, it's of course necessary that the splicers be correctly installed. But I don't know how much of an issue that might pose. Or whether there are any fitment instructions available..
Good Fortune! :)
22 May 2012 11:57
#524021
Good Fortune! :)
Should all measure the same resistance, with or without the splicers, or with only one splicer.
Good Fortune! :)
  • badrhino
22 May 2012 17:10
#524070
I am getting around 15,000 ohms at the end of the splicer. But when I put the wires on and test the end cap I am getting really high readings like (Left: 74,000) and (Right: 24,000) It makes no sense. Shouldn't the readings be around 5,000. And why would the readings go up instead of down?
Franken Z!
22 May 2012 17:28 - 22 May 2012 17:31
#524075
Because there is something wrong with the connection of the splice. Take the splices off and read the resistance through each splice by itself. Red on one end of it and black on the other end. This will verify the splice itself isn't introducing the resistance. If it is zero, which it should be, then the problem is in how the wires are being connected to the splice.
Repeat the above test but substitute the plug wires for the splices. If they read zero ohms then its the connection.
Last edit: 22 May 2012 17:31 by DiamondSkyBlue1000.
22 May 2012 18:23 - 22 May 2012 18:26
#524095
badrhino wrote: I am getting around 15,000 ohms at the end of the splicer. But when I put the wires on and test the end cap I am getting really high readings like (Left: 74,000) and (Right: 24,000) It makes no sense. Shouldn't the readings be around 5,000. And why would the readings go up instead of down?
More resistance results in higher ohms. Less resistance results in lower ohms.
Measuring between the splicers shows resistance in the secondary winding inside the coil. And should be the same as measuring the resistance between the cores in the stub ends without the splicers.
Measuring between the caps adds the resistance offered by the resistor plug wires.
24,000Ω on the right is probably okay.
But 74,000Ω on the left seems way too high (perhaps due to faulty connection through the splicer).
For comparison, the stock Z1, with solid core (non-resistor) plug wires and resistor caps, is supposed to measure about 30,000Ω when measured cap to cap, which would include resistance in the secondary winding plus resistance in the stock resistor caps.
Measuring between the plug wire leads, without the resistor caps, would be less resistance.
Good Fortune! :)
Last edit: 22 May 2012 18:26 by Patton.
  • badrhino
23 May 2012 00:54
#524184
I took the new wires off multiple times and re-installed and same thing or nothing. Finally took them off and tested the new wire it self and those things are junk. You have to hit it just right to get a reading. I finally got them back on and am getting 23,500 ohms out the left coil and 24,000 out of the right coil. These suppression wires def. add more resistance. If I had to do over I would definitely buy solid core wires with resistor caps. What a PITA!
I hope those numbers will work. I guess I will find out tomorrow if that is why one of my cylinders wasn't firing all the time.
Franken Z!
  • badrhino
23 May 2012 14:53
#524273
Well that didn't help the issue any. Still not getting proper firing in #4. I am waiting on my tools to do a valve adjustment if needed. How come I can take the plug wire off of the #4 plug and sit it on there and it fires better than when it is securely on the plug.
Pardon my ignorance:It's been a while dealing with carbs.... But I also noticed when I had the bike running when you revved the bike up you could see mist come out the back of #4 carb. is that normal or is that the sign of a mis-adjusted valve blowing pressure back out.
Franken Z!
