- Thank you received: 1
LEDs won't work!
- gumby prichard
also, on the other thread, i noticed that said something about how the ground wire had to be mounted to the rubber grummet? mine is ordereed like this...light, rubber grummet, washer, headlight mounting bracket, ground wire, nut. Should the grounding wire be touching the rubber to isolate it from the frame so the order would be signal light, ground, rubber grummet, washer, mounting bracket, nut????? im not usre what else would be the problem...i have also heard that you must buy a LED flasher relay, an electronic relay will not work. is this true? THANKS!!!
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- MFolks
- Thank you received: 540
Most Kawaski motorcycles have as a ground wire one marked with a Black wire with a Yellow stripe.
For any rubber isolated turn signal to work, it must make good metal to metal contact. Possibly your bike has some rust/corrosion where the pieces meet.
The rubber acts like a vibration dampner so the turn signal filaments are not shaken to death. I'd check your fuses too as I suspect one or more may be bad.
You should be able to take the new LED's and power them directly with the battery to see if they work.
- mtbspeedfreak
- Thank you received: 36
CF12ANL-01: LED Bulb Flasher Unit
Electronic LED Flashers have no minimum load-12VDC
Eliminates the need for load resistors, turn signals will flash at normal
rate with or without LED bulbs
2000 ZRX 1100
1976 KZ 900- Daily Driver
- gumby prichard
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- gumby prichard
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- gumby prichard
tomorrow i will post pictures and see what everyone thinks, because this is driving me insane. I hate wiring. In the meantime i will also post my wiring diagram.[img]http://http://www.kz400.com/Techh%20tips%20bilder/Wiring%20diagrams/kz400-B1us-canadianmodel2.jpg[/img]
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- gumby prichard
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- Rainman
- and a little Kaw shall lead them
- Thank you received: 75
The front turn signals on your 400 were 2 filament, 2 wire (1 for turn and 1 for running light on with headlight). The black/yellow wire is the ground, the gray is the right turn, the green the left turn and the blue is the running light (same in both lights). The ground was thru the turn signal body and had a ground line under the mounting nut.
The rear signals only had 1 filament, 1 wire (turn signal only) and ground thru the body like the front.
For LED signals, you will need an electronic flasher (2 pin). Available at any auto parts store for under 10 dollars.
Check the LED lights at the battery, they will only work in one direction.
Assuming red is positive and black is negative/ground.
The red wire will connect to the green or gray (left or right, front and rear) and the black will connect to a black/yellow wire or grounded to the frame.
The blue wires will not be used.
On your wire diagram,
the brown wire is power in to the flasher,
the tan is from flasher to the swith.
When the switch is activated (left),
the power goes to the green wire (left turn light, and indicater bulb) and then to ground.
This current activates the flash function in the flasher at a fixed rate regardless of the amount of current draw (bulb wattage) of the lights (or LED,s).
Good luck,
Jim
80 KZ750 H1 - the Kaw calf
79 KZ750 Twin - Miss Nov 2008 KZR calander
79 KZ750 Twin parts bike
78 KZ650 C2 Parts Bike
75 KZ400 Wife's old bike sold
81 KZ440 A2 LTD Wife's new bike
84 Honda 450 Rebel Wife's newest bike
Jim
Quincy,IL
- gumby prichard
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- gumby prichard
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- 82HONDASAKI
What did you find out? i just got a custom modded kz1100, I want to convert all the taillights and turn signals to LED but i dont know enough about motorcycles yet and electrical conversions. let me know what all i would need to order, thanks
- mtbspeedfreak
82HONDASAKI wrote: Hello Gumby,
All you'll need will be the LED bulbs and an electronic flasher. In theory. :whistle:
2000 ZRX 1100
