Persistant Blow of 20A Main Fuse
- PLUMMEN
Re: Persistant Blow of 20A Main Fuse
20 Aug 2010 22:26
- Old Man Rock
20 Aug 2010 22:30
Ah crap... I said the word Electron flow and ole Plumm got a chubby..... (Wood).... :laugh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- alexnelson
20 Aug 2010 22:42Something caught my eye in your last postings....
Disconnect the headlight harness plug and re-test....
Fuse blowing?
First thing I'm trying when I get home . . .
78 KZ650-D1
K&N pods + 4-1 Pipe
Mikuni VM24 - 7.5/115/#4 Clip
Dyna-S
Dyna 3-Ohm Coils
Vancouver BC
K&N pods + 4-1 Pipe
Dyna-S
Dyna 3-Ohm Coils
Vancouver BC
- Old Man Rock
20 Aug 2010 23:00
Alex.... D-connect the instrument cluster harness connector as well and re-test...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Motor Head
21 Aug 2010 07:09
Those Fluke Fuses aren't exactly cheap either. I've been OK with mine at a steady 10AMP, but somewhere above then Poof it goes.
I remember your thread your post now, did you check that the rubber ring, at the head lamp bucket, where all of the wires come in is in place and hasn't cut into some insulation? There is 2 of these 1 on each side of the bucket.
- alexnelson
21 Aug 2010 21:14 - 21 Aug 2010 21:16
Went through a good 12 fuses before I ran out working on it today. Unplugged all the lights. Fuse still went. Then things got kinda strange. I had the thing running for a while, the fuse hadn't blown for a good 6 or 7 minutes. I figured "ok. I'm gonna take this thing for a ride". As soon as I sat on the bike the fuse went. This got me thinking. I put a new fuse in and tapped the frame with a piece of wood, fuse went. I was able to reproduce this about five times. Then it stopped. Anyway, back at it tomorrow with more fuses, more meter, less stick.
78 KZ650-D1
K&N pods + 4-1 Pipe
Dyna-S
Dyna 3-Ohm Coils
Vancouver BC
K&N pods + 4-1 Pipe
Dyna-S
Dyna 3-Ohm Coils
Vancouver BC
Last edit: 21 Aug 2010 21:16 by alexnelson.
- Old Man Rock
21 Aug 2010 21:21 - 21 Aug 2010 21:26
"tapped the frame with a piece of wood, fuse went. I was able to reproduce this about five times."
Uhm Alex, wasn't once enough to inform you you have a short occurring under your seat pan due to your fat ass? :blink:
:laugh: :laugh: :laugh:
Sounds as though your real close to finding your culprit... Once you do, yell out real loud.... Then beat the hell out of that short with your stick....
You'll feel much better... :woohoo:
BTW, not sure about the KZ650 harness runs but for my 900, harness is under the seat pan for the run to the rear tail/brake light assembly....
hmmm....
hmmm....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 21 Aug 2010 21:26 by Old Man Rock.
- alexnelson
21 Aug 2010 21:48
I hope against hope my fat ass is responsible for all of this.
Harness to all my back lights runs right under the seat pan. So, I unplugged it. Fuse still blew.
78 KZ650-D1
K&N pods + 4-1 Pipe
Dyna-S
Dyna 3-Ohm Coils
Vancouver BC
K&N pods + 4-1 Pipe
Dyna-S
Dyna 3-Ohm Coils
Vancouver BC
- elfmagic17
21 Aug 2010 22:14
alexnelson wrote:
I've never tried it but I'm sure it works, Take a 10 AMP circuit breaker and replace the fuse with it, bike on and circuit breaker kicking in and out use a magnetic compass to follow the wires it will point to the short. Was a trick I was tought in my electronics class in automotive collage at University of Northwestern Ohio.78 KZ650 D1
I started a thread about this a while back but haven't been able to work on things for a while. I figured I'd start a new thread because so much has changed since the first post.
My main 20A fuse blows as soon as my bike warms up. I fire up the bike and without touching it at all, the fuse will eventually go after about 2 minutes. If I replace the fuse immediately after that and try to start the bike again, the fuse will blow instantly. Sometimes it blows as soon as I turn the ignition key but this is only after the bike has warmed up.
Due to scorch marks and excessive heat (will burn your fingertips) around the connections to the reg/rec, I thought maybe I had a bad reg/rec. A couple people told me to unplug the reg/rec and see if the fuse still goes. So I did that, the fuse still went.
This leads me to believe there is a grounding problem elsewhere, though, I have searched high and low on this thing without any luck. I've opened up the controls and headlamp almost a dozen times, no exaggeration, and can't see anything.
Is there anyway to use a meter to track down something like this? I feel like I'm just shooting in the dark here.
Kenny Hicks
74 Honda CB550
74 Honda CB550
21 Aug 2010 22:23 - 21 Aug 2010 22:24
Thanks a whole bunch, Kenny.
Now I've gotta dig around and fine my compass. :laugh:
Last edit: 21 Aug 2010 22:24 by Patton.
- kawsakiman
21 Aug 2010 22:38
do you have a new battery?
21 Aug 2010 22:46
alexnelson wrote:
According to wiring diagram for this model, the front blinkers also serve as running lights, always ON, and receiving voltage when ignition switch is ON.
Such continuous voltage is fed through the blue wires into the flashers (probably coming from a dual connector inside the headlight shell).
When tightening the nut, perhaps the blue wire was shorted against the flasher stalk.
If not already done, could disconnect the blue wire feeding left flasher from the connector inside the headlight shell.
And re-test.
...It all started when I opened my headlamp to tighten the nut holding the left signal light to the headlamp housing. Now you're all thinking, "Well, your problem must be in there!" Maybe it is. But like I say, I've had then thing open so many darn times and can't see anything wrong....
And re-test.
