1980 750H bare bones for mattylight
- DannyBlanco
Re: 1980 750H bare bones for mattylight
31 Mar 2014 20:14Would I be able to go battery less on a 78 750? With battery my bike usually takes about 3 or more kicks to start. And if possible would you be able to do this schematic bare bones for kick only? Thanks for your help in advance.
- loudhvx
01 Apr 2014 09:31 - 14 Jan 2019 18:49
Batteryless 1978 Kawasaki KZ750B3 twin for DannyBlanco
EDIT 1/14/2019:
Mattylight Barebones Bare Bones
1978 Kawasaki Kz750B3 twin batteryless for DannyBlanco
Kz750B Kz750 B3 Kz 750 B 750B3 750B
EDIT 1/14/2019:
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 14 Jan 2019 18:49 by loudhvx.
- DannyBlanco
03 Apr 2014 17:30
:woohoo: Thanks I really appreciate it Loudvhx.
- dynastydudge
06 Apr 2014 13:15
if i may sir. could i get a bare bones diagram for a 1982 honda cm 450. i want a toggle switch on/off instead of igniton. headlight bright only. tail light. and brake light. electric start only it doesnt have a kick start. if you could include what guage the wires need to be that would be awesome. when the toggle switch turns on lights go on and it can be started. toggle switch off kills the bike. not sure if thats possible but thats what i am ideally going for...thanks in advance dude...really a great service your doing here spreading the knowledge.
were not here for a long time, just a good time......1980 kz750 ltd h1
1982 honda cm 450e
1982 honda cm 450e
- loudhvx
06 Apr 2014 14:26
Sorry, I don't have any info on a cm450.
1981 KZ550 D1 gpz.
Other links.
Other links.
- dynastydudge
07 Apr 2014 00:58
No problem sir. Thanks anyway. I have learned a lot just reading this thread.
1982 honda cm 450e
1982 honda cm 450e
- jhnmik13
17 Apr 2014 14:25
Im looking for a bare bones wiring diagram,for a 83 kz550f1
17 Apr 2014 16:56
For reference --- Here's the essential wiring needed for Kawasaki's electronic ignition, with a battery, to kick-start or bump-start the engine and keep the ignition firing until the battery discharges.
There's no charging system (i.e., no generator, rectifier or regulator), and no chassis wiring for lights, switches, etc.
Most likely a little too spartan for most street riders, but could be okay for an hour or so of daylight racing.
- loudhvx
08 May 2014 06:47 - 14 Jan 2019 19:13
1981 KZ550A2 or 1981 KZ550C2 for Ironhead_mikey@yahoo.com
5/8/14
EDIT 1/14/2019:
1981 Kawasaki Kz550 for IronHeadMikey
Kz 550
5/8/14
EDIT 1/14/2019:
Kz 550
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 14 Jan 2019 19:13 by loudhvx.
- GuyShocker
01 Jul 2014 18:09
@loudhvx are you still making these diagrams?? If so, I really could use your help.
I have a 1981 GPZ1100B1 which was converted from FI to carb. Right now, my bike is in need of wiring magic. I saw this thread, and can not start to say what amazing work you've done to help everyone out.
With that being said.. I have a wiring nightmare that needs addressing. I would love to have the bike bare bones as possible, and need your expertise. The bike needs the following...
-Battery
-Headlight
-Tail light
-Signals
-Series of toggle switches to replace key'd ignition.
-Button start/kill
-Retain original charging system
The toggle switches will be hidden at my disclosure. The bike will not run gauges or require any safety lights (neutral, blinkers, oil..)
Can you help a fellow rider out?
-Battery
-Headlight
-Tail light
-Signals
-Button start/kill
1981 GPZ1100B1 Danger Zone
- loudhvx
23 Jul 2014 22:03 - 14 Jan 2019 19:14
1981 Kawasaki KZ110B1 Gpz for GuyShocker
EDIT 1/14/2019:
1981 Kawasaki Kz1100B1 for GuyShocker
Kz1100B Kz1100 B1 Kz 1100 B 1100B1 1100B
EDIT 1/14/2019:
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 14 Jan 2019 19:14 by loudhvx.
- loudhvx
06 Nov 2014 10:35 - 02 May 2019 11:01
1981 KZ440 for user CoffeeBrake on the twins forum.
EDIT 5/2/2019:
1981 Kawasaki Kz440 for CoffeeBrake
Kz 440
EDIT 5/2/2019:
Kz 440
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 02 May 2019 11:01 by loudhvx.
