- Thank you received: 1415
new dyna coils cracked
- KZQ
- Administrator
Thank You
KZCSI
OK, Here goes, I'm opening this thread. I'm here online and I'll delete the whole damn thing if it gets out of hand.
Mr. 13thLevel,
You've got a chance to learn something here, as we all do. Regarding your claim that the 3 ohm Dynas caused the problem, most of us doubt it! Please, in a civil manner, teach us something.
Let's see what unfolds.
KZCSI
Post edited by: KZCSI, at: 2007/08/29 20:19
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
- KZQ
- Administrator
Did you ever answer my question about the running voltage of your system?
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
- 13thlevel
Hi Mr. 13th Level,
KZCSI
Please explain to me why Dynatek, the company that makes the coil, would tell me I was sold the wrong coil if most of you don't think it's the wrong coil. Can you see my frustration? The bike ran fine for about three or four months after I bought it. Then one day, a coil (1 COIL) goes bad. I contact a dealer and receive a pair of GREEN dyna coils as the replacement. I install these two green Dyna coils, coil wires and plugs. The bike fires right up and runs great for about 10 miles or so. Then all of a sudden while riding I loose 2 cylinders. I check the coils and discover one is cracked in half. I then proceed to try to get the bike home by running on two cylinders. After a mile or so, the bike completely shuts down and won't start. I check the coils again and discover that both are cracked in half. I then have to pay over $120.00 to have my bike towed home. I contact the dealer that sold me the coils and they say it's my bike that damaged the coils, but I should contact the manufacturer to have them replaced. After contacting the manufacturer I'm informed I was sold the wrong coils after all. Now after asking for help here I am treated as though my bike is the culprit once again..........can you see my frustration now?
I can't do any checks on the bike for a day or so, I'll have to get back to you on that.
- BSKZ650
There are a lot of people on the site that have been there, done that, got the tee shirt to prove it several times over
77 ltd1000, current rider
76 kz900, just waiting
- The Milkman
- Thank you received: 194
I personally have no idea why the coils would do that even if they have the wrong resistance.
I had to modify my mounts some to get the dynas to fit my 650. When I first mounted them, they were pretty tight on the frame and was putting stress on the coils. And had to install nylon spacers on the primary end to keep the screws that hold the wires on from grounding out. I used longer nylon spacers on both ends to drop the coils a bit. Other guys have just used tape on the original metal mounting spacers. Hopefully, this wasn't your problem.
Ride safe.
- steell
from www.dynaonline.com/english/dyna_coils.htmBefore selecting a coil, check the coil primary resistance requirements as specified by the manufacturer of the ignition being used.
So, what does the Factory Service Manual say the primary resistance should be?
I don't have a manual for the 900/1015 motors or I'd look it up.
- Jeff.Saunders
The coils splitting is not likely to have been caused by the resistance. As others have stated, many, many other bikes have green coils with points. The negative of 3 ohm coils with points - it tends to cause the points to pit a little quicker than with stock coils - but you're looking at 2-3,000 miles of life versus 3-4,000 points life... the positive of the green coils is they generate a better spark - something most owners benefit from - especally with cold blooded, hard starting bikes. The 3 ohm coils are also a better match with the Dyna-S ignitions - something the majority of owners also switch to at some point.
Dyna 3 ohm coils are a nominal 3 ohms - when you measure them you get 3.3-3.4 ohm readings. The factory Kawasaki coils will read from 3.4 - 3.8 ohm when new.
As stated previously, and others have stated, you likely have other issues causing this problem.
How old are your points / condensors? If the points are pitted, it's time to replace both the points and condensors.
I suspect your regulator has failed and your bike is over charging badly. Check your battery fluid level and see if any of the cells are down on liquid - if so, a sure sign the bike is over charging and your regulator is bad.
If the bike is currently back firing through the carbs, you may have mis-wired the coils and have 1/4 and 2/3 feeds reversed, or have the plug wires running to the wrong cylinders. One simple way of checking is to remove the plugs from the head, put them in the plug cams and ground them on the cylinder head. With the ignition on, turn the engine over slowly with a wrench on the end of the crank, when you see a spark on a plug check that cylinder is at top dead center. You can also look at the ignition advancer and see if it matches the markings on the advancer.
Once you get the bike running, you need to check the voltage at the battery - at idle you should see 12.5-13 volts. as you bring the rpm up, the voltage reading will rise until it caps around 14 volts. If the readings continue to climb past 15 volts your regulator is bad for sure. In some bikes you will see readings as high as 18 or more volts - enough voltage to cause major issues.
Often you would notice lights getting brighter and brighter as the voltage climbs.
Post edited by: Jeff.Saunders, at: 2007/08/30 08:46
www.z1enterprises.com
Z1 Ent on Facebook,
- cnyl
- Thank you received: 5
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
www.myspace.com/tukrhill
- wiredgeorge
As far as using the green coils with points, there is absolutely no reason not to other than the a set of points will not last quite as long... certainly won't cause the coils to crack. The 5 Ohm coils that Dyna suggests just extend the life of a set of points a bit but either the green or black coils work fine. I would ALWAYS recommend the green coils because when the owner upgrades to an electronic ignition, my opinion is that the black coils don't produce as hot a spark as the green with the electronic ignition and actually perform no bettter than the OEM coils did.
I think for a new coil to crack down the middle, it would have had to been mounted grossly wrong (doesn't sound like it in this case) or the coil had to be grossly overheated. I have left a key on overnight with green Dyna coils (don't tell anyone I made a mistake hehe)... and it didn't crack the coils. I would use a multimeter and check the resistance of both the primary and secondary windings for a short... the short will generally be caused by MAJOR overheating and this could only be caused by the voltage regulator being dead... in other words very high voltage feeding the coils.
As has been noted, when the bike only backfires when coils have been installed, it is likely the black and green wires from the points have been installed on the wrong coils... black to 1 and 4 and green to 2 and 3 coil. Trace the wires up to the coils and see what plugs the plug wires go to. Normally, the 1/4 coil is on the right as you sit on the bike.
As far as how this issue has been handled, I personally would have been embarrassed to have a customer complaining and making demands in this forum without having actually contacted me. Have to take my hat off to Jeff Saunders for not ignoring this guy or telling him to pound sand after his temper tantrum. That stoic Brit demeanor serves you well!
For Sandy/Patman: hehehe Bud!
- arai59
- Banned
BTW Jeff.......since your an old red coat....:laugh: do you have a good recipe for tartar sauce ? Or is malt vinegar still the rule for fish and chips ?:woohoo:
Post edited by: arai60, at: 2007/08/30 21:50
- Norseman
13thLevel, victims will never be victors. You're upset,but everyone that has posted has both expressed empathy and tried to help with very little info on the issue. You really need to listen to them and take their advice and instruction. You will fix the problem, learn, have a great bike, and feel accomplished that you have done so. Give them a chance to help you.
And give Jeff a call at Z1, you know what to say...
- 13thlevel
My bike obviously does have other issues. One of the new coils (black) failed on me today. And my headlight burned out within seconds of starting the engine (I assume this means the regulator is faulty). Karma sucks.
Oh and the backfiring was indeed crossed wires. I had connected the green to green and black to black, for some reason mine are backwards and I had to connect green to black and black to green....?
So in the end, I'm the moron. Oh well I'll live and you all will get over it....:dry:
Hey does anyone know if I can purchase a single black coil and a voltage regulator from z1.....I'm to embarrassed to call and ask.
