  • Page:
  • 1
  • 2
'81 GPz550 No Startie Thread 05 Apr 2024 12:31 #897283
  • chopper1963
  • chopper1963's Avatar Topic Author
  • Thank you received: 8
1981 GPz550 stock engine. Refreshed top end. Confirmed cleaned carbs. Pods because I don't want to do the airbox dance again. I saw through the pilot jets with my own eyes.
Battery is confirmed good.
Confirmed ignition by pulling 1 and 4 plugs, laying plug on cylinder head and seeing spark.
Confirmed fuel in bowls by cracking each screw on bottom of bowl. Fuel flows out.
Spins but will not do the first start. Choke on, choke off. No difference.
Tried a short spray of starting fluid on pods. #3 cylinder popped back a bit twice, but other than that, dead.
Spins over well.
Suggestions welcome.
TIA
'81 GPz550 No Startie Thread 05 Apr 2024 13:51 #897289
  • Warren3200gt
  • Warren3200gt's Avatar
  • Thank you received: 665
Have you checked  you have full battery voltage to the coils? A spark from a plug laying on the head may not spark under compression when fitted if voltage to coil is low.
Z1000J2 somewhat modified!
The following user(s) said Thank You: chopper1963
'81 GPz550 No Startie Thread 05 Apr 2024 14:42 #897293
  • sf4t7
  • sf4t7's Avatar
  • Thank you received: 258
Hate to admit this here, but when I tried starting my "refreshed" Z1 I got sort of a backfire thru the airbox and no start, but had spark with plug laying on head.  Turns out I had the coil trigger wires from the generic dyna ignition reversed. Switched them and it started right up.  (In my defense, the colors of the trigger wires on the conversion are white for 1-4 and black for 2-3; and I got them mixed up : wires from original points were black for 1-4 and green for 2-3).  It was still a noob error.         Maybe that happened to yours?  If so it's an easy fix !
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
'81 GPz550 No Startie Thread 05 Apr 2024 15:09 #897294
  • chopper1963
I talked to my mechanic who suggested the same. Going for an inspection now.
'81 GPz550 No Startie Thread 05 Apr 2024 18:50 #897306
  • chopper1963
Do you happen to know what the battery voltage is supposed to be to the coils?
'81 GPz550 No Startie Thread 05 Apr 2024 18:51 #897307
  • chopper1963
I confirmed that the coils are connected properly. I also swapped to another set of functioning on a second bike carbs. Still spins like crazy and no start even on a shot of ether.
'81 GPz550 No Startie Thread 05 Apr 2024 20:23 #897310
  • sf4t7
  • sf4t7's Avatar
The coils should be getting as close to full battery voltage as possible,  I added the "wired george relay" to mine.  See Wookie's post from april 2022 titled "ignition by-pass relay - W"
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
'81 GPz550 No Startie Thread 06 Apr 2024 06:01 #897313
  • chopper1963
No joy
'81 GPz550 No Startie Thread 06 Apr 2024 06:49 #897314
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2081
No power to coils, or power to coils but no fire?
'81 GPz550 No Startie Thread 06 Apr 2024 08:22 #897316
  • Nessism
  • Nessism's Avatar
  • Away
  • Thank you received: 2684
Cam or ignition time may be 180 degrees out.  Don't ask me how I know...
Ignition can be checked by switching coil leads.  Cam timing is best checked with the plug out, watching visually to make sure 1-4 is at the top of the stroke before you verify the cam timing marks are correct.
The following user(s) said Thank You: chopper1963, howardhb
Last edit: by Nessism.
'81 GPz550 No Startie Thread 07 Apr 2024 05:45 #897337
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
  • Thank you received: 377
Another vote for checking the cam timing. Is there suction at the carb? Have you tried a shot of ether to rule out a fuel problem?
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
'81 GPz550 No Startie Thread 07 Apr 2024 06:15 #897338
  • Rolf1976_KZ900
  • Rolf1976_KZ900's Avatar
  • Thank you received: 122
After a start attemt Check if the plugs are wet. If they are dry and this sounds silly but did you remember to set the mixturescrews out. Check compression and as already mentioned check timing.
  • Page:
  • 1
  • 2
