I've got a 83 GPz1100 that has been converted to carbs, as parts and the special diagnostic tools for these early FI systems are obsolete.
With yours, I am with Steve. Get VM 26's or 28's with the carb air box and associated bits and block off the injector holes with threaded bolts or aluminum plugs. I have a lathe and have made aluminum threaded plugs to close everything from injector ports to spark plug holes. When I first got the bike, I tried to get it inspected for certification with the injection removed and carbs installed. At the time, I was in a hurry and didn't have enough time to make all the block off plugs I needed. The only thing I could find that had the correct thread to plug the fuel return line in the bottom of the fuel tank was a 14 mm spark plug from my Honda. I put a plug cap on it too. just for fun.
When the inspector asked why there was a spark plug screwed into the fuel tank, with a perfectly straight face I told him it was the bike's self destruct mechanism. He just about blew a gasket himself "why in hell would you want to do that?" he asked. I said I was a MI-6 secret agent, and had to have "Q" custom install it, a machine gun in the headlight, and a passenger ejector seat...he still didn't get the joke.....
