I got some garage time today. Started out working on this one:
Attachment 0722161911.jpg not found
Ended up working on this one:
Attachment 0722161912.jpg not found
So far:
- I tried doubling up the foam without bothering to oil, no change
- I tried moving to a finer foam, with oil, very little change. At this point, the foam I've got in there is close enough to stock that I don't think the foam is my problem.
- I gave the carburettors a very detailed cleaning, again, very little change
Here are my symptoms:
When I first start the bike, it runs quite poorly for about 30 seconds, have to play with the choke to get it to fire and to keep it going (I suppose that's probably not all that strange). After some initial warm-up, it'll maintain a low idle with no choke, purrs like a kitten. For the first minute or so, the instant I give it any gas, it'll stall. Another minute or so, and it can take a little gas, but will begin to chug, and quit if I roll on the gas slowly. Once I hit a certain warmup point, if I roll it quickly to WOT, it'll run right up to redline like a champ, but if I wind the grip slowly, it'll stall. As it warms up, I can wind it up more slowly, bit it's basically impossible to stick the needle at 2500 RPM (it'll backfire through the carbs) until the bike is good and warm. After it's good and warm, it runs fairly well, but even well warmed, if I run it under a light load (i.e .up a slight hill) at about 1/4 throttle at around 2200 to 3200 RPM it'll periodically miss and/or backfire through the intake/carbs.
I adjusted valve lash less than 100 miles ago. I did have the head off earlier this year (had another thread on here about low compression), but the symptoms were there prior to pulling the head, so I don't think it's valve timing. I did clean a bit of carbon out of the head and piston top when I had it apart, so I don't think it's running lean. Plugs are unremarkable. About a year ago, I spec'd the coil and it was just barely outside of spec (it was a while ago, so I don't really remember what the resistance came out to), so I convinced myself that it was probably 'fine for now', though I do wonder with the carbon build-up, and 'borderline' spec on coil if I could just have a cold spark, The spark is definitely more yellow than blue with the plugs pulled.
As far as the carb cleaning, I used a set of torch tip cleaning wires to clean every hole of the jets (including the ones through the sides of the tubes), visually inspected for light, blew with compressed air, hit the small hole between the two jets, etc. I do have an in-line filter to catch tank debris.
Compression is, of course, good following the top end rebuild, so no concerns there.
I'm really leaning towards bucking up and replacing the coil. Does anyone have a dissenting opinion/suggestion?
