Finally got a second crack at trying to get KZombie to fire-up tonight and stwange things were afoot.
First a sanity check for me, since all of my manuals do not show the vacuum ports connected to these VM24SS carbs and any exploded views I found searching here (over an hour now), still leave me wondering if perhaps my vacuum lines are wrong?
So here's the carbs in question, in situ:
Do I have my vacuum lines connected properly?
Pic one above, RED cap on carb 2, is plugging one port which I thought was connected to the emissions reed valve setup. Black hose below it routes to a "T" connector which is connected to carb 4 seen in Picture two. From the T connector the vacuum line is routed to the petcock although the hose is currently plugged without the tank on at the moment.
I connected the fuel line (seen in the second picture) to a bottle of fuel for test run. When I filled the bottle, every carb gushed gasoline out of the over-flow tubes and down to the garage floor at the center stand (ie: the over flow tubes are all routed to behind the engine, between the center stand and swing arm.
This never happened on Sunday when I tried to start the engine. I had exactly the same setup without any drama (or engine start).
In the searching tonight I found
[ Nessim's Notes on these carbs problems ]
about the floats jamming up and the jets clogging easily.
I'm just puzzled because none of this happened on Sunday and the bike has only sat in the garage since then until tonight's attempt.
Additionally, as I was trying to start the engine, I noticed gasoline was dripping from the carb mounts - all of them -
So basically, I'm assuming I was flooding the engine as it tried to start. My thought was - OK, this is obviously too rich... and then shut off the choke and went WOT and rolled on the starter. Amazingly, the engine behaved like it was going to start for about 2 seconds until eventually my battery dropped below 10vdc.
I replaced my plugs tonight because I discovered I made the blunder of installing B
R7ES plugs before and read recently that was a no no. I confirmed spark at all four B7ES plugs and with the ignition cover off, I could clearly see the points sparking during rotation. I also confirmed the points for 1 and 4 had the black wire and points for 2 and 3 had the green wire (so points to coils is wired correctly - I thought maybe this was the problem on Sunday).
I am going to pull the carbs AGAIN!
argh! and completely dismantle them to see why they all poured fuel out the over-flow tubes (this happened all night. I dried up the floor and next attempt to start, more fuel on the floor). So the bowls are obviously full and based upon gas dripping from all four of the carb mounts, I'm flooding the engine; right?
Am I missing anything else? I need the sanity check here. Thanks in advance for any wisdom y'all can impart.
