There is a tl'dr version at the end.
I picked this bike up about a year ago from the (third?) owner as a project, who had been riding said bike the previous summer but left it sitting for a while. The bike, at the time, was stock with the exception of pods. I got the bike home and cleaned the carbs, got a new battery, and after kicking it over for at least half an hour finally got it started. At this time it ran okay, though it smoked which I assumed was due to all the dirt and grime on the head. It also had a hanging and increasing idle problem, which I will explain later.
After measuring the compression of the bike, I found that it was quite low and after throwing a spoonful of oil into the spark plug sockets and trying again deduced that it was the piston rings. So I pulled the engine apart with a mechanic as a mentor and replaced the rings. He took it upon himself to call in a favor with a buddy who has a machine shop and got the valves ground, so he re-lapped them and we put everything back together (there was a few month time gap here due to us both being busy and on completely different schedules). During this time, I also rebuilt the carbs with carb rebuild kits from PartsNMore (I live in Canada, and their prices are very reasonable).
About a month to a month and a half ago I put the motor back in the bike, spent another 40 minutes trying to start it and bam, it started. BUT, it had almost zero power, along with the hanging idle problem. At idle, after letting it run for a few minutes and on about 3/4 choke, revving it up (eventually to 300-4000 rpm) and letting out the clutch would just cause it to stall trying to head back up the driveway into the shop (though the driveway has a slight grade to it, it wouldn't by any stretch of the imagination qualify as a steep one). I also noticed while the bike was sitting that one carb was overflowing so I pulled the carbs apart, measured the float height which was fine, and gave them a brief clean which seemed to solve the problem then.
At this point I started cruising forums and saw it mentioned that incorrect valve clearance could cause a lack of power, so I took apart the cylinder head and measured the valve clearances, ordered new shims, and installed them. I also ordered a Dyna S ignition system with 3 ohm coils along with the ignition system which I then installed with the shims and adjusted the timing. When I measured the clearances, they were way off. I triple checked my math, and it was right, so somehow I must have measured the clearances on an angle and got incorrect readings. I figured I would try to start it anyway and see what happens (probably because I was pissed off at the time, not entirely sure).
Of course, it wouldn't start. With ether I could get slight ignition, but no catching. I pulled the valve cover off again and put the old shims back in, and rebuilt the petcock, removing the small screen which was gunked to shit and clogging everything, and replacing and lubricating the O rings. I also noticed when removing and draining the carbs that two carbs weren't even filled which I found weird, so I pulled the carbs apart, blew out every passage with compressed air, then cleaned it with carb cleaner and blew it out again.
Yesterday I put everything back together and tried to start it up which ended up being a no go (no surprise). It would start and hold a brief idle using quick start (ether) but wouldn't stay started, or start at all without it.
So now I'm here, asking what to do next. There are probably a few things I forgot to add here that I've done as well. Any reply would be appreciated.
tl'dr Bike won't start, the following is a timeline of stuff done to it
- Came stock except has pods, no breather filter though
- Cleaned carbs and it started, but had hanging & increasing idle problem (carb flooding maybe)
- Low compression, determined it was rings. Put new rings in, ground and re-lapped valves, and put everything together again with new gaskets, and rebuilt carbs.
- Got it back and started, had no power and very rough idle (though could have just been choke. I couldn't idle it without the choke.).
- Put Dyna S in and 3 ohm dyna coils (7mm supression plug wires), rebuilt petcock.
- Carbs were flooding, so measured float height which was fine and cleaned carbs, seemed to have solved problem.
- Figured lack of power could be valve clearances, so measured, calculated, and ordered new shims.
- Put shims in, re-measured clearances, and got wrong measurements. Figured I measured at an angle one of the two times and was completely off.
- Tried to start the bike anyway (because I'm stupid) and didn't start
- Put old shims back in, bike wouldn't start. Noticed that the outermost carbs weren't getting gas, so blew every passage out of carbs, cleaned with carb cleaner, and blew passages out again.
- Will start briefly with ether, but won't even catch without it.
If you got all the way to here, I commend you. Any insight anyone can offer would be much appreciated. Thanks! (also didnt proofread this so there are probably a lot of errors, but it's late. And I work tomorrow.)
