ezrider714 wrote: Always start with the float body measurement, to get you in the ball park so the bike will run...enabling the ability to do the clear tube test"
Where do all you people, that claim to only us the clear tube test, set the float initially????
In all my years of experience, I have never found a large variation, using either/both methods..... The important part is that they are all the same. as close as humanly possible
One helpful factor is that even though a lot of carbs are "crudded up" and neglected because the bike has sat for years. the float heights are often as set at the factory so regularly you get pretty lucky and they are pretty close unless you are really unfortunate and someone really incompetent has been working on the carbs. Most of the carb "bodgers" don't mess with the floats, they are usually to busy rounding of screw heads and cross threading things.
If possible I'll check the float heights with the clear plastic tube before taking them off the bike, or before dismantling them, that way you know if adjustments are needed and which way to bend which float tab, if at all. As often many have not been molested, this avoids doing a dry setting and then perhaps adjusting them back to where they already were when you get to the clear tube stage.
