  • Page:
  • 1
  • 2
1978 kz650 replacement float bowl 12 Apr 2014 17:31 #628820
  • Fkh34d
  • Fkh34d's Avatar Topic Author
  • Thank you received: 0
I have a 1978 kz650 and after a long week of scratching my head as to to why the carb float bleed off was always dripping I found that it was the bowl it self was leaking right from the bleed off tube. Can anyone point me towards where I could find replacement float bowls.
1978 kz650 replacement float bowl 12 Apr 2014 18:05 #628825
  • Thank you received: 2829
Finding a replacement bowl may take some time. Remember to get the bowl that matches the side the carb is on. The drain screws on 1&2 face the opposite direction than that of carbs 3&4. In the meantime, you may want to try replacing the brass tube. Here's a link to some info on that process. Ed
www.kzrider.com/forum/3-carburetor/58956...heard-of-this#593985
1978 kz650 replacement float bowl 12 Apr 2014 19:07 #628827
  • Fkh34d
That actually really helps. I realize finding replacements is gonna be a pain. One thing I noticed about the bowl in question is it differs from the rest. The bowl that leaks has a 2 stamped on the inside while the other 3 have a 1 stamped in them. Makes me think that someone replaced it before. I will try that fix as it would be simple and easy. But I think I'll wait till I do find new ones.
1978 kz650 replacement float bowl 13 Apr 2014 04:37 #628841
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1630
Which carburetor & do they have the accelerator pump? Can you post a photo of the float bowl?
You might be able to find something on eebbaayy. In the mean time if the leak is at the base of the overflow tube, you can try using an epoxy to seal it. Permatex liquid metal might work. I've used the stuff a couple of times for the petcock & low fuel switch, and it has held up to gasoline --- no leaks.
Last edit: by martin_csr.
1978 kz650 replacement float bowl 13 Apr 2014 12:54 #628888
  • Nessism
  • Nessism's Avatar
  • Away
  • Thank you received: 2685
I have a LH side float bowl from some Suzuki VM22's. It's yours for the cost of shipping if that would help.
1978 kz650 replacement float bowl 14 Apr 2014 13:30 #629011
  • Mellvis
  • Mellvis's Avatar
  • Thank you received: 3
I can send you one for the cost of shipping + the cost of 1/2 of a can of Michelob Ultra Light. As said above, can you post a picture so I know if I have the right one. I have some just laying around.
1978 kz650 replacement float bowl 14 Apr 2014 15:00 #629017
  • Fkh34d
Yea I'll post some pictures when I tear it down Wednesday or Thursday. Have some parts from z1e coming and I'll do it all at once.
1978 kz650 replacement float bowl 14 Apr 2014 16:27 #629026
  • peter1958
  • peter1958's Avatar
  • User is blocked
  • Thank you received: 198
post a picture and I will mail you one. free i pay shipping.
1978 kz650 replacement float bowl 14 Apr 2014 16:33 #629027
  • Fkh34d
Ok I will post a picture tomorrow first thing after work. Thanks to everyone's generosity
1978 kz650 replacement float bowl 17 Apr 2014 12:36 #629418
  • Fkh34d
Here is the float bowl in question
Attachment ImageUploadedByTapatalk1397763334.198122.jpg not found
Attachment ImageUploadedByTapatalk1397763346.580409.jpg not found
Attachment ImageUploadedByTapatalk1397763359.730469.jpg not found
1978 kz650 replacement float bowl 18 Apr 2014 11:40 #629506
  • Fkh34d
Update to anyone still following:
Attachment ImageUploadedByTapatalk1397846413.989153.jpg not found
I have removed the leaky brass tube from the bowl. Now the hard part finding another to replace it
1978 kz650 replacement float bowl 18 Apr 2014 15:31 #629530
  • peter1958
  • User is blocked
I will get over to the garage sat and find you one
  • Page:
  • 1
  • 2
